VeX THIS!!! (a VeX/Parallax Hybrid has been started!) — Parallax Forums
gelfling6gelfling6 Posts: 60
edited 2006-07-08 20:17 in Robotics
Well I am VEXed, Book-2!
Okay, Despite what IFI (Inovation First, Inc.) says, yes, you CAN make a Parallax/VEX Hybrid.
I just drove a VEX servo full scale, through 256hz to 1256 Hz., with a homework board.
Now, drawback, the servo did, indeed need a higher voltage to run. So..
VEX Motor/Servo pin-out: W O B
key || |
| | | White = Signal
| | | Orange= V+ (Vin)
| | | Black = GND (Vss)
| | +--Vss
220ohm | +---Vin
P0|=>
I imagine, IF fed from the Vdd pins on the Board Of Education, because of the outboard LM7805, the servo may
run just fine, because the regulator on the Homework board is too small, and can't handle the load of the servo.
The servo moves fairly rapid. and I imagine +9V is WAY too high. (will need to get a 7805 to see if this is true.)
But, it works!! and, yes, You do notice a new reset button on the board. Somehow, one of the tabs on the
old switch broke off, and I lost the top & disc from the reset, so.. unsoldered the old switch, and tacked-on
a new one.
The other drawback, with the VEX motors & servos. is the short, Unsecured square shaft.
You're limited by needing some of the VEX hardware to be driven off the servo or motor.
My Geo-Crawler is almost completed, and now, the BS2 looks more like a viable source for GPS interfacing.
(haven't figured all details of trying to connect the ETrex to the VEX controller.)
(my Geo-Crawler, is supposed to be a Semi-Autonomous 'tank-crawler' that will use a Garmin ETrex, to
locate certain Lat/Lon positions, where people have hidden 'GeoCaches' (small hidden treasure).)
Stephen (gelfling6)
  • SuperwormsSuperworms Posts: 118
    edited 2006-05-15 22:13
    nice
  • BamseBamse Posts: 561
    edited 2006-05-16 02:05
    I know the VEX servo and motor works on 6 volts, even better with 7.2 volts.
    I would not stretch it over 7.2 volts since that is what the VEX battery is made for...
    Both the motor and servo is working fine with the BOE, I'm working on·a tank-bot with VEX parts and the BOE...
    Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
    Experience level:
    [noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
    [noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
    [noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
    [noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
    [noparse][[/noparse] ] I dream in SX28 assembler...
    /Bamse
  • iamscottymiamscottym Posts: 30
    edited 2006-05-16 06:31
    IFI actually makes some pretty nice robot control systems...i happen to have one from a year I did it. It uses a 40 channel data radio, and the robot controller side has 30 or so pwm ports and 10 relay ports, and the human side interface has 3 analog ports for joysticks. Its overpriced for what it is, 1500 or so for everything, but its great.
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2006-05-16 14:51
    I'll get some picutres of my Parallax driven VEX bot as soon as I get further along with it...
    Ryan
    Ryan Clarke
    Parallax Tech Support
    RClarke@Parallax.com
    edited 2006-05-16 15:24
    I went to the First Championship 2006 in Atlanta just to scope things out undercover (although I was wearing my Propeller T-shirt). smilewinkgrin.gif
    Needless to say I didn't understand the stereo type that you could only use VEX robot products.· This way of thinking stifles creativity
    in my opinion.· My understanding is that each team is given a "goodie" bag of various pre-made robotic parts that they are to use in
    their final design. (<-again this stifles creativity)· As a result most of the designs end up looking very similar to each other.· This
    aspect didn't do much for me, I was hoping for much more of a variety of robots to truly appreciate the creative talents I believe were
    present at the contest.· What a shame, my 3 1/2 year old daughter was with me ( quite the tom-boy ; loves robots and trains, won't touch
    a doll) Even she was disappointed and even made comment "daddy we've already seen this one, let’s go somewhere else".· This coming
    from someone who will watch a "robot video clip" over and over and over again.· She especially likes robo-rats.
    FRC (First Robotic Challenge)
    FLL (First Lego League)
    FVC (First Vex Challenge)
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/16/2006 3:28:51 PM GMT
  • gelfling6gelfling6 Posts: 60
    edited 2006-05-17 23:49
    Glad to see I'm not the only one breaking the VEX stereotype. Their website seems even more
    stifled, with most of the posts in the forum, coming from just ONE tech from IFI, and Almost
    ALL forums, locked, and unable to post a reply. (even to ones, where if you read the answer,
    the tech made an error.. You can't make a follow-up.)
    The servos & motors are fairly generic, with just the add-on 2-post mount, and the close-quarters
    socket for the drive clutch. (which, itself, the spring seems too strong.. If I turned a jammed
    servo, it would chew the internal gears to death 1st, before the clutch released.)
    If you were down in Atlanta, I hope you got to see some of the beginning teams on the Newton
    playing field.. (Specificly, Team 1124, the Avon Uberbots.. I hoped their final design
    worked better than it's 1st incarnation, and as well as it did at the regional here in Ct.)
    Okay, I wanted to show-off the 1st version of the Geo-Crawler to one of the team members,
    while doing the late bus run, so I left the base VEX robot w/tank treads on the engine cover of the
    bus. (I drive a schoolbus, incase everyone else hasn't caught on.).. then, went to turn into the high school..
    Down it went into the stairwell.. the frame bent, and it snapped one of the tank tracks. shakehead.gif
    Never do this one again! nono.gif stopped, picked it up, hand mended things, but the broken track
    needed to be replaced. went to pick up the kids, and Keith (the robotics team member) saw the mess..
    Oh-well.. I replaced the track when I got home, and finishedd fixing the bent plates & frame.
    I also needed to replace all 4 long screws for the servo. One, the head snapped off.. and, when I went to
    remove the servos, the hex head stripped-out (from a hex, to a circle!) shakehead.gif
    Found out, Never build the 'SquareBot' design in the manual, then run it outside on grass..
    Mucks-up the gears! (to say nothing of the mud & dirt the drive gear picks-up. so close to the ground,
    what were they (and I ) thinking?)
    I'm thinking of finding an old dial phone, and pull the RJ connectors from the handset & phone, to
    see if I can decipher the RC reciever.. just need to figure out which pin is which, then feed the
    data & clock streams to a BS2.
    next step, once the Robot is stable (body wise) will be connecting, and programming the
    BOE board. Already making a Molex to coaxial adaptor, to run the BOE off the VEX battery.
    Stephen (gelfling6)
    edited 2006-05-18 18:43
    Finally...
    Yeah, it's really that old...
    Here is my VEX-BOE-Tankbot or whatever it is...
    Notice the "Expansion board" mounted on the sensor platform...
    The motors works just like ordinary RC servos (Black = Vss, Orange = Vdd and White is the Pulse (1-2ms))...
    The limit switches can be seen as pushbuttons that shorts black and white during contact, I don't know if red is connected or not...
    Anyhow, time to order some sensors (from Parallax) to put on my "Expansion board"... smilewinkgrin.gif
    Experience level:
    /Bamse
    1110 x 774 - 133K
    1127 x 762 - 135K
    edited 2006-05-19 00:24
    Bamse said...
    Finally...
    No, the red wire is usually open, or Vdd, for the ones that use it. found this out with a damaged bumper switch.
    (the white wire, & copper trace ripped from the board, and the wire goes through the board!)
    Okay.. Here's an intersting question to put to the techs at Parallax...
    The VEX ultrasonic range sensor, is comprised of 2 devices, and 2 wire sets (3-wire).. the device comes with NO
    sample code, which you must get off their website, and actually, it IS included with the programming kit,
    but only in bare minimum. It is supposed to use two interupt ports of the VEX controller, but is very vague..
    How does this concept, compare to the PING? is the PING connected in similar fashion?
    If yes, Bamse, If you can track-down one range finder, there goes an add-on for your scanning platform. turn.gif
    If anything, trying to find parts for these, is also turning into a major scavenger hunt. RS must indeed, be planning on
    discontinuing the whole shooting match. I already faced-down one baracuda manager, and told him point-blank,
    "when I said I was looking, I ment I was looking! But, since you decide to continue an "assault sales pitch", you just lost
    any possible sale.. Good day!", and walked out. Sorry.. I'm just not a hard-sell kind of customer.
    BTW, I LOVE the breadboard! Always leave room for expansion! smilewinkgrin.gifburger.gif
    Stephen (gelfling6)
    edited 2006-05-19 14:08
    Stephen,
    I don't have the VEX Programming kit and I don't think I'll get it either...
    I was more thinking of the PING actually...
    Unless VEX let us know the specifications I'm not going to try VEX Ultrasonic sensor...
    However I do need some parts from Digikey so I think I will try out the Sharp GP2Y0D21YK (Digikey Part 425-1168-ND), hopefully it will fit the sensor server...
    The RS store here in Tyler, TX seem to be OK, if I tell them I'm just looking, they leave me alone...
    However, if I buy anything, they'll ask me if I need a new cell-phone with that, kind of annoying...
    This weekend I'll hopefully be able to make a small platfor to mount the BOE, it's lying loose on the bot right now so I'll guess it's just a question of time before it will get caught in the tracks... wink.gif
    By the way, I was looking for the connectors for the VEX battery so I could hook it up to the BOE and it looks like it is Digikey WM2308-ND and WM2311-ND...
    Experience level:
    /Bamse
    edited 2006-05-19 21:41
    Bamse said...
    Ironicly, I think RS does have it.. Look in the section with RC batteries, I think they have the Molex connector, in raw,
    and with wires pre-attached. (fairly sure on the pre-attached, I made a pair of aligator clip adaptors, for a battery charger,
    and found the female end, fits the VEX battery pack. (see attached photos) and, being NiMH, as well as the NiCad pack,
    both fit the charger's female plug as well (sorry, no photo yet.)
    Stephen (gelfling6)
    (added 05/22-06) and 3rd photo, is exactly what you're looking for.. female pin molex connector, to 'Type M' barrel
    connector... Bought the plugs, and the 9.6V repair kit, as I needed to fix the 6-battery VEX module.. (4th photo)
    where the V+ wire came un-attached.. (sloppy Crimp job, Guys! )
    Center is V+, shield is V-
    Post Edited (gelfling6) : 5/22/2006 10:31:07 PM GMT
    510 x 382 - 48K
    512 x 384 - 53K
    511 x 383 - 36K
    511 x 323 - 36K
    edited 2006-05-24 22:12
    Keep skimming over the Vexlabs page, for bits & pieces, although, in the FAQ section,
    you still cannot post anything.. (questions, etc.) BUT..... I did find, one little piece
    of usable info.. the pin-out of the RX!
    the radio reciever, is a simple 4-pin interface..
    Pin 1 = +5V
    Pin 2 = Data
    Pin 3 = GND
    Pin 4 = Tether detect. (shorting this to GND, on the transmitter, blocks the transmitter, from another msg.
    showing how to wire a multi-pole single through switch to control competitions.)
    Data is in a solid stream, of single digits, 0 to 255... So.. here's the fun part....
    #1, at what baud rate?
    #2, what does each value mean?
    #3, can it be interfaced with a BS2? (simple enough, YES! Just have to figure #1 & #2 1st.)
    You could probably hack an old RJ14 socket, from an old Bell phone, solder-solidify the wires,
    and plug them into the board. +5, would go to Vdd, and the data would be at TTL level.
    Someone mentioned, in another discussion, the wrong model for the PIC18 chips..
    Both are PIC 18F8520 (not 8452, I seem to remember..)
    Despite IFI's & Intelitek's remarks, I believe Microchip DOES make a version of the
    MPLAB, which works on a Macintosh. (just, it seems, IFI/Intelitek, Doesn't want to
    invest the time/money, IMHO)
    I've just finished the drivetrain for the Geo Crawler. so-far, it reacts well with the VEX controller
    & TX/RX.. (needed to adjust chain tension, and track tension. (loosened both! had a major
    binding problem with the tracks being too tight, and the chain kept skipping off the sprokets.,
    then one chain too tight, kept binding. All loose, it runs like a champ!)
    Now, next step.. Pulling the VEX controller, and mounting the BOE. I'm gonna have to make some
    custom "Z" brackets, to make-up for the mis-allignment between the corner holes of the BOE, and
    the perforations in the metal frames.
    Stephen (gelfling6)
    edited 2006-05-25 14:44
    I was actually going to try and read the signal sent to the servos from the VEX controller with a PULSIN command...
    However if we could "crack" the code from the reciever, that would be awesome... cool.gif
    Keep me posted and let me know if there is anything I can do to help...
    Experience level:
    /Bamse
    edited 2006-05-25 22:06
    Bamse said...
    Will do! The signal sent to the servos, is about the same as the BOE sends to the servos on the BOE-BOT,
    Actually, I found the VEX motors are almost identical to the Parallax constant rotation servos, as far as
    pulsout ratio.. (173-176 Hz range holds stopped, anything outside down to 90, is full rotation, up to 250 is full.
    (and FAST!!! jumpin.gif ) I finally got the nerve, and gutted one of each, of the servos, and the motors..
    The servo, has a 100Kohm pot directly under the drive wheel, driven by a odd cam imbedded into the drive wheel.
    and it's NOT an easy thing to disassemble. It's held by 2 plastic clips > <-like. and almost as hard re-assembling.
    The Motor, has NO adjustment! it's just a plain, simple control chip, and some drive electronics under
    the board. I'd venture guess, Not impossible to re-fit into the Parallax servo case, (2 offset screws hold the motor into
    the VEX case. and, that odd cam imbedded in the servo, is non-existant. I'd imagine, worse case, you could pull the
    cam out, set the servo POT to dead center, and make it into an emergency motor, if it weren't for the tab on the wheel.
    (See various documents on converting plain servos into constant rotation.)
    I'm planning on getting an RJ14 plug from an old AT&T phone handset, and see if I can solder the wires, and plug them into
    the BOE, and do a little remote analyzing of the signal.
    Just for laughs, I actually tried to write my 1st program, in Easy-C.. No serialin, no serialout, VEXLABS says the RX & TX
    pins on the I/O port side of the controller is supposed to have similar access to the USER 18F8520, like the
    programming cable has to the Master 18F8520.. I've yet to find any code that demonstraits how to talk to this.
    (to say nothing of it is TTL level.. )
    One thing I'd kill, to figure out.. Mad Katz, a maker of all kinds of Sony Playstation, Sega, Nintendo, XBox, etc.. controllers,
    makes a 2.4Ghz wireless PS2 controller. The signal is Bi-Directional, via a small postage-stamp sized PC board, with a
    pin row.. On both ends! (Identical, in the controller, and the module you plug into the PS2)
    I'd love to find out the pin-out! it would make for a wicked 2-way serial between the BOE, and a computer.
    It's supposed to be able to transmit back to the controller, as well as the controller to it, to activate the vibration
    motors in the controller handles. *sigh!* more to have to look at.. rolleyes.gifeyes.gif
    Okay, back into the laboratory (a small workbench I also use to repair computers.)
    Stephen (gelfling6)
    edited 2006-05-29 19:32
    Okay, here's what I've been able to extract from VEXLABS...
    (quoted from two posts by Ricky Terrence, on vexlabs forums)
    Here is pinout for the RX1 or RX2 ports:
    Pin 1 - Power +5 volts (the right most pin when looking at the front connector)
    Pin 2 - Receiver
    Pin 3 - Gnd
    Pin 4 - Tether Detect (the left most pin when looking at the front connector)
    The pulse width from the RF Receiver is 0.870 – 2.15ms and has a period of 18ms. This
    signal will be decoded by the Vex Micro Controller to a value from 0 – 255. The
    control signals are TTL levels where as your computers serial port is at 232 levels.
    You can damage the Vex Micro Controller if you do not do a level conversion.
    ----end quote---
    At present, I'm trying to connect the VEX reciever, to a homework board, adding an external 7805
    regulator, to power the receiver. Objective, is seeing if I can detect a standard serial pattern from
    the receiver, and send it back through to the debug output in decimal.
    The Geo-Crawler, is taking a little more shape.. (See photos) Adding the ultrasonic range finder,
    and two limit switches to the front. (I took your idea for the scanning head, Bamse!)
    I just fed it my 1st few programs from their programmer.. Ever seen one of these run amuck?
    (It's not pretty!) tried to re-create the demo videos of the PING demo, once in a certain distance,
    scan for clearest path, turn to it, then continue. It ran forward, then went into circles.
    Stephen (gelfling6)
    510 x 382 - 63K
    508 x 383 - 71K
  • Zsy6Zsy6 Posts: 37
    edited 2006-05-31 15:38
    Hey gefling6, can you attach the BS2 file you used to turn your vex motor so I could use it to test the vex servo I just got with my boebot?
    Also, I don't really understand how you set up the servo on the breadboard, where do u plug it in, Vdd or vin, what do u need the 220 ohm resistor for?
    edited 2006-05-31 19:43
    Try this:
    Plug the VEX servo into your breadboard...
    Connect Orange to Vdd (or Vin if you are using a battery no more than 7.2 V).
    Connect black to Vss.
    Connect white to p0.
    Then try the following program:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    Start:
    PULSOUT 0, 500
    PAUSE 20
    GOTO Start
    The VEX motor should now turn in one direction, switch 500 to 1000 to reverse direction...
    Experience level:
    /Bamse
    edited 2006-05-31 22:37
    Zsy6 said...
    the 220ohm resister was probably overkill, since the homework board is already isolated with 220ohm chip resistors...
    Bamse has it right.. orange goes to VDD (+5V, though on the homework board, I highly suggest a 7805 regulator's
    output. (and V+ on the 7805 to Vin).), Black to Vss (GND), and the white wire, to your pulse source.
    the drawing got clobbered by the way most forums reformat text..
    Bamse's driver, is just for 1-way.. I had it going bi-directional..
    (hope this appears right, I'm running 8 things on a 512MB 1.113Ghz P-III laptop, and it keeps threatening to go nova!)
    Pgm: VEX_This.BS2
    'Let's STAMP this VEX!
    'A simple test program, to modulate a VEX servo motor, with a
    'Parallax Basic Stamp2 Homework Board (or a Board Of Ed)
    'By Stephen Griswold (gelfling6@hotmail.com)
    'basis: Can IFI/Radioshack VEX servos & motors be controlled by a BS2?
    'Answer: YES! and this proves it!
    'Pulsout zone values, are approx 256 to 1256 for full travel.
    ' NOTE! Homework board will need a 7805 regulator to power
    ' the servo or motor's V+ pin. The On-BS2 regulator cannot handle
    ' the load. (and +9V is way too high!)
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    zone VAR Word 'This is our value area
    DO
    ' Roll from low to high zone.
    FOR zone = 256 TO 1256 'Slow, but yes, it will step all 1000 areas.
    'Steps of 4 make for 200 positions
    DEBUG CRSRXY, 0, 2, DEC4 zone 'display on terminal where we're at.
    PULSOUT 0, zone ' I chose Pin0, for the test.
    PAUSE 10 'a 10-ms wait state.
    NEXT
    ' Now, roll from high to low zone
    FOR zone = 1256 TO 256
    DEBUG CRSRXY, 0,2, DEC4 zone
    PULSOUT 0, zone
    PAUSE 10
    NEXT
    LOOP 'And do it again.
    END
    (expect that to get clobbered)
    this ran the servo.. You can use the exact same values the Parallax constant-rotation servos
    uses, with the VEX motor modules. (650-750-850 range. The VEX 0-127-255 range must add
    a value to match the servo's requirements.)
    Okay, I may've stubbed some toes, in the Vexlabs forums. saying there should be an open
    minded bridge, to allow other items to interface to VEX.. Haven't been there to see if I'm canned, or not.
    (saying creating is chief, and isn't one of their slogon terms, "Create"?)
    Hope this helps, Zsy6! Stephen (gelfling6)
  • DaddioDaddio Posts: 2
    edited 2006-05-31 22:38
    I noticed that you have the VEX Ultrasonic Range Finder attached. Would you please include any interface information you have discovered for the BS?
    Thanks.
    edited 2006-06-01 16:31
    I accidentally bought the vex servos...
    I thought they were continuous rotation, but they only go 100 degrees, they wont be very useful for motion...
    edited 2006-06-01 18:41
    Zsy6,
    You may be able to modify them for continuous rotation...a google search will turn up many sites with how-to's for modifying servos. The process may be a little different for the VEX servos (I'll have to check on this)-
    Ryan
    Ryan Clarke
    edited 2006-06-02 00:27
    Zsy6 said...
    Try this....
    remove the screws from the top section.. lift off the center step-down gear, and the end drive gear (the one with the square hole)
    underneith the end-drive gear, you'll find a whaite plastic insert, looking like a bow-tie, with a slot in the center. remove this piece
    (it should be held in by 2 pin-tabs) by 1st prying the bronze bushing out, then grabbing or prying the plastic piece out. then, replace (press-in) the bronze bushing.
    Now, using a file, an xacto knife (CAREFULLY!!) or even grabbing with a pair of pliers, on the top of the end drive gear,
    is a small tab. (C) <---<<< (note center of C as the top view) file-down, whittle away, or grab & twist the tab, so it
    won't block the gear from rotating full-circle.
    now! make sure the tab in the center post of the end drive gear spindel, is dead-center (=). (You just did the centering of
    the potentiometer)
    Final steps, place the end drive gear on, along with the center step-down gears (small gear face downward.)
    before replacing the cover & screws, hook it up, and feed it a low-rotation pulse. (about 750 center, so 650 or 850)
    this should show if the tab is still there enough to bind things. If not, the end drive gear should rotate 360 degrees.)
    Now, finish re-assembling.
    as far as I disassembled one of my servos, (all the gears off, 2 screws off the top of the motor, THEN remove the 4 bottom
    case screws)
    the pot is held by 2 plastic fingers into the case body, with 3 long metal strips feeding up to it.. I imagine, you could un-
    solder the pot, and replace it with a PC mount, then drill a hole through the side to adjust. (or, even feed the existing pot's
    the two top screws of the motor, are tiny! be careful not to lose them! *plink!* OH-RATS!!! nono.gif
    Stephen (gelfling6)
    edited 2006-06-02 11:44
    Is there anything you don't know?
    lol
    edited 2006-06-02 18:28
    Any info about the Ultrasonic Range Finder?
    Thanks.
    edited 2006-06-02 21:14
    Zsy6 said...
    lol
    Yeah,
    Why am I still single. turn.gifblush.gif .
    I haven't delved too hard into it yet, Daddio.. Right now, It's connected to the VEX controller,
    but I imagine, seeing little code to run it, and seeing quite a few minor chips on the board
    itself, and, seeing quite a similarity of minimum chips & ransistors to the PING, (Okay, I admit it,
    I downloaded the PING specs from here.) the wiring shouldn't be that much off.. Majority of the
    VEX modules, are 3-wire, Vss (Gnd) Vdd (+5V) and signal (either input or output).
    input is apparently turned on by a signal from one of the digital I/O ports, and the output is fed to
    one of the interupts, I'm guessing, to feed the actual echo count.
    the subroutine, is locked away in one of the user libraries (and, knowing IFI, next to impossible to decipher.)
    and returns a simple 0 to 99 value.. (0 being closest, 99 being within 2-Ft. (1/2-meter. or so.)
    I'm half tempted, see what I would get, if I wired the sonar like the PING, and fed it the test program for
    the Ping.. It stands to reason, the pulse fed to the digital output, is a clock, and the interupt is simply a count,
    and match to what was sent, and the software deciphers how far away.
    Mind you, I'm hardly more than a high school graduate, yet, totally geek by my own hands, and learning.
    I'm slowly baking my brain, trying to learn ANSI-C, and see if I can write a rudimentary program for the
    VEX controller itself., and worse case, link the VEX to either the homework board, or the BOE..
    Okay, I may be stubbing toes here.. skull.gif PBasic, can't be the native language of the stamp.. Otherwise,
    you would be typing programs directly into the RS-232 port, instead of writing them on a host computer.
    Rather, it is tokenized data, fed to the PIC chip on the stamp.. The program on the PC (or mac, or..)
    is strictly a compiler. Right? idea.gif and the idea of the VEX, is the same as programming a stamp.
    write the program offline from the host computer, upload & run the compiled program onto the PIC.
    I may end-up outboarding the homework board, to the VEX, and re-feed it the test program for the sonar.
    then, tap the input & output wires into 2 pins of the BS2, and see what is being generated..
    rather than re-invent the wheel, The wheel may already be made. It just may need a different hub to connect
    Stephen (gelfling6)
  • Bill PlanoBill Plano Posts: 14
    edited 2006-06-03 00:21
    Stephen:
    While everyone else is picking your brain, have you figured out the encoders that Vex has.· I see by the documentation, that there are 100 slots in them.· I would like to use them for my Sherline Mill which has .050in per turn of the handle.· There are three wires, red, white, black.· I assume +5v, gnd, signal.·
    Just in case· you have used them, I would apprecitate any info you may be able to pass on.
    Bill
    edited 2006-06-03 23:47
    Bill Plano said...
    Stephen:
    While everyone else is picking your brain, have you figured out the encoders that Vex has. I see by the documentation, that there are 100 slots in them. I would like to use them for my Sherline Mill which has .050in per turn of the handle. There are three wires, red, white, black. I assume +5v, gnd, signal.
    Just in case you have used them, I would apprecitate any info you may be able to pass on.
    Bill
    Sorry, Bill, I haven't.. I was looking at them at a store a few weeks ago, and they almost looked like
    a set of wafer switches I pulled from an old Atari 2600 trackball.. (difference being, the ones from
    the trackball were SPDT (explained further down) instead, these look like simple on/off ( SPST) shutter
    like.. (0101010101 pattern) yes, the majority of the VEX stuff is plain +5, GND, Signal.
    the Atari trackball encoders, used a staggered shutter switch, to tell which direction it was turning..
    One side would remain 0, while the 2nd turned 0, then the 1st would turn 1, then the 2nd, 0..
    00110011001100110011 -side 1
    01100110011001100110 -side 2 as they connected to the common pin..
    The VEX encoders just send a simple pulse.. Thinking you already know which way it's turning,
    just needing to know how far..
    Well, It's official.. I STINK at 'C'! freaked.gif My initial program to run the geocrawler, as a
    Along side, I'm also trying to develope the same program, for the BOE... Same problem as
    Bamse... Needing to retrofit a mount for the BOE.. I must've botched a condition check
    somewhere.. It ignored the auto/manual switching from the remote (monitoring switches on Ch 6
    to either run autonimous, or manual control) removing that part of the code, it does the scanning
    for a new direction IF it finds an obstruction within 1-foot, but, it always runs backwards. roll.gif
    It seems I also forgot to add a 'STOP!" if it does find an obstruction.. nono.gif So, I guess I
    Back to the drawingboard!! (and a little more time using pbasic)
    Stephen (gelfling6)
    edited 2006-06-26 00:03
    Bill Plano said...
    Stephen:
    Bill
    And, recap.. My previous note, they are indeed digital encoders.. I broke-down, and bought a pair last week.. But, as I mentioned in the note, they are strictly 1010101010101010... stream.. the +5V powers the IR LED in the pick-up, and the GND common,
    and the signal, from the white wire, from the photo transistor, shows a "0" for an open slot in the wheel, and a 1 for a blocked
    signal. I am mystified, by why they have a slide-off cover.. eyes.gif the area inside the box doesn't appear to have any way for debris to get in, but I guess they aren't taking chances, and giving the user a way to blow dust & debris out, if it gets inside. (worse, if the wheels aren't aligned perfectly center, I imagine the encoder wheel does rub against the case.)
    I'm baffled even worse, by the line follower modules.. They also have the same wiring.. +5(red) to the IR LED, GND (black), Signal (white) .. no way to retrofit, to do a IR remote.. just simple feedback if the beam of IR is broken.
    I need to revisit the VEXLabs page.. Someone made a direct-drive robot, with seriously flexible framing. calling it a rock crawler. Using 4 of the knobby tires, on a pair of rubber-band stabilized axles. I can't remember how the axles were made.. (the motors were mounted on the ends, and the wheels driven directly off the motors.)
    I made a alternate pair of driving frames on mine.. The tank tracks on one set, the knobby tires on the other set. and the tires move wicked fast! far too fast for stopping within a foot. time to modify the geocrawler's distance programming.
    Blasted wet weather here in the north-east US is getting me a bad case of cabin fever. Hardly any chance to really let the geocrawler out to test-drive.
    Stephen
    Seems there are a few other VEX pages popping up! and I'm passing on tips from here, and personal
    tips I've learned too..
    www.vexfan.com
    www.botmag.com (has a side discussion about the VEX)
    Stephen
