Using a propeller as a intelligent communication hub
Hello
I'm a newbie here, so I hope my question is not already answered somewhere inside the forum.
I'm thinking about using a Propeller chip in a multi-processor system for a robot. The Propeller would be linked serially with multiple slave PICs coprocessors.
From what i gatered so far, every time a USART objet is started in Spin, it uses a cog. So this would mean that I can only run 3 USART objects at once in my system;
3 USART comm cogs, 3 other cogs to process those feeds, 1 cogs for main control program, 1 "leftover" cog.
Would it be possible that 7 cogs run USART communication AND process information ? The remaining cog would run the main control program. This setup would be ideal i think. Also, I would be nice if the 7 cogs would not need to continually "swap" between separated comm USART program and proccessing program.
Even if you run the USART COGs at 19200bps, you will only receive about 500 32bit Lwords/second, and unless you have some very advanced processing to do on those streams, I can't see why you need 3 COGs to process the information.
Remember, the Propeller has 32KB RAM and you can use a lot of that for buffering data.
The Propeller can supposedly start up a COG with a new object in a few uS if it's running at 80MHz. This means that every time a slave is deemed not to need 'supervision' for even a few mS, the COG that was communicating with it can be reused for another task. (Like communicating with another PIC or processing data?)
I mentioned 19200.
That is what a Spin-based FULL-duplex USART does. Now, imagine what a Half-duplex assembly-based USART would be able to do...
(you don't need better than half-duplex in a master - slave setup)
Don't visit my new website...
If you do want to assign a COG for each coprocessor (although why offload the functions to a coprocessor if they can't work independently for a little while?) and the transmission rate is low, you could reload the USART when you need it and keep the processing of the feeds in the same COG. The "swap" doesn't take long (a couple of hundred microseconds). Conceptually it is simple to do that.
(Yeah, bad habit. I'm on a twelve step program to quit)
Why use the PICs at all?
Every COG is more powerful that the PIC it will be communicating with, and letting the COGs take over the task directly will remove the delays in data transfers.
I will use multiple PICs on a same comm line. But i will not go for adressable USART since all PICs on the line would get an interrupt each time an adress is put on the comm line. I think i will go for a direct signal from the Propeller to each PIC to get their attention for communication exchange.
I have attached here a revised sketch of my project.
I you want to look at it, keep in mind the following;
-altought is a complex project, i want to keep things simple and manageable
-I want to build an homebrew robot controller based the ideas of subsumption architecture (invented by this Rodney Brooks guy). I have also been inspired by the robot project "Seeker" of Dave Shinsel.
-I want to use PICs for low-level control, and reserve the Propeller for high-level control
1) If you are going to have a line from the Propellor to each PIC, then I suggest that you use that line for the actual communication. You can certainly use a standard asynchronous serial signal for that purpose, possibly signaling the PIC by using a "break" signal (a long low ... several bit times long) and waiting for an acknowledgment.
2) The COGs really are equal in status and do not need the complexity of arbitration
3) Some of the PIC functions might best be done by the Propellor itself like servo control. depending on the number of digital lines, that might also be done well by the Propellor. I don't mean to discourage you from using coprocessors, but that does introduce another level of complexity and the possibility of error. If you don't really need it, you're better off doing the functions in the Propellor. You might consider using two Propellors if you really need the i/o lines and the simultaneous functions. I know PICs are cheap, but, once you get 6 to 8 of them, you're introducing complexity that may be easier to manage with the two Propellor chips. SPIN is a much more powerful language with debugging tools even now at an early stage than you can get with PICs, particularly since you can do TV output with only a few resistors. It can also do A-D and D-A conversions and servo control easily and cheaply.
Unless the robotic applications are extremely complex, or the I/O count exceeds the the chip's capability, my expectation is that a single Propeller with all of the COGs running assembler can likely handle all the work required.
Experience with a lot of assembler code for SXes, continues to amaze in the amount of work they can chew through with ease. In the Propeller we have eight comparably powerful machines, each slower, but with a wider and more competent instruction set, and with a great hub-communication system. The mind boggles at what can be achived with this chip by the upcoming crop of competent assembler programmers....... and an integrated single Propeller approach will surely simplify all the PIC communication layers anticipated.
That said, only Mr. Bricole knows the level of complexity contemplated; my suggestion is....... don't write the single Propeller approach off prematurely!
Cheers,
Peter (pjv)
1+1=10
