EmbeddedBlue Transceiver AppMod???
·how can i communicate full duplex wirelessly using EmbeddedBlue Transceiver AppMod to another 2 or more·EmbeddedBlue Transceiver AppMod??
please help me on this and if there any other alternative?
The Embeddedblue is only capable of communicating with ONE other BT-based unit at a time.
If you want to communicate with more devices you'll have to do something like this:
(Pseudocode, don't type it in)
GOSUB Connect_blue1
GOSUB transmit_Blue1
GOSUB Disconnect_blue1
GOSUB Connect_blue2
GOSUB transmit_Blue2
GOSUB Disconnect_blue2
GOSUB Connect_blue3
GOSUB transmit_Blue3
GOSUB Disconnect_blue3
How to connect and disconnect IS described quite clearly in the manual.
Also, which processor are you using?
(The BS2 line can't do full-duplex)
Don't visit my new website...
it will take a lot of time to connect and disconnect each device.
i need fast transfer from one device to another.
http://www.parallax.com/detail.asp?product_id=28180
They won't do higher than 19.200, but as you don't specify how high speeds you need...
Edit: Probably not, as these won't be able to do Full-duplex, only half-duplex.
i might try using that one.
