EmbeddedBlue Transceiver AppMod??? — Parallax Forums
louislyxlouislyx Posts: 5
edited 2006-06-01 04:34 in General Discussion
·how can i communicate full duplex wirelessly using EmbeddedBlue Transceiver AppMod to another 2 or more·EmbeddedBlue Transceiver AppMod??
please help me on this and if there any other alternative?
    edited 2006-05-31 06:53
    Did you read the documentation?
    The Embeddedblue is only capable of communicating with ONE other BT-based unit at a time.
    If you want to communicate with more devices you'll have to do something like this:
    (Pseudocode, don't type it in)
    GOSUB Connect_blue1
    GOSUB transmit_Blue1
    GOSUB Disconnect_blue1
    GOSUB Connect_blue2
    GOSUB transmit_Blue2
    GOSUB Disconnect_blue2
    GOSUB Connect_blue3
    GOSUB transmit_Blue3
    GOSUB Disconnect_blue3
    How to connect and disconnect IS described quite clearly in the manual.
    Also, which processor are you using?
    (The BS2 line can't do full-duplex)
    Don't visit my new website...
  • louislyxlouislyx Posts: 5
    edited 2006-05-31 09:13
    i am using other microprocessor which have serial interrupt?
    it will take a lot of time to connect and disconnect each device.
    i need fast transfer from one device to another.
    edited 2006-05-31 10:07
    Maybe the 433MHz RF Transmitters can be used?
    http://www.parallax.com/detail.asp?product_id=28180
    They won't do higher than 19.200, but as you don't specify how high speeds you need...
    Edit: Probably not, as these won't be able to do Full-duplex, only half-duplex.
    thanks for the recomendation.
    i might try using that one.
