i fried my boebots serel to paralel converter
and i do not no wat to do can eney one hellp me?
A BS2 does not have a serial to parallel converter, by the way.
(Note the 'native' windows USB drivers don't properly detect the USB-BOE board's FTDI chips -- you MUST install the FTDI drivers before plugging in the USB cable. No harm done if you haven't -- you can unplug the USB cable and install the FTDI drivers even now.)
In other words, good communication is dependent on commonly accepted standards.·
Every language has homophones and you can easily encrypt your meaning to such, but many people will just ignore what is presented in such a confusing fashion.
Please, I beg you to try to make it easy for the reader.
Post Edited (Kramer) : 5/27/2006 5:22:07 PM GMT
Did you put an 'electrically live' unprotected board on a metal surface?
Generally static destroys individual loose components.
Once they are in the board, static generally only can zap the I/O if it gets a chance to do so.
Did you switch the plugin of the USB after the original setup?
I have a lot of USB ports [noparse][[/noparse]4 USB1.0 on the mother board and 4USB2.0 in a card]
My Parallax provided driver only works for COM4 which is a USB plug in the front of my computer.
If I switch to the back [noparse][[/noparse]which is seen as COM1], it doesn't work.
If you did switch, try going back to where it first worked.
