body parts
Quick question: Does anyone have a Web link for metal robot body parts, i.e. metal with holes pre-drilled (in various shapes and sizes)·for construction of different styles of robot for use with the BOE or the BS2p24/40 Demo Board
, like·a four wheeled model? I have found a universal plate here
http://www.hobbyengineering.com/H2032.html
but I think it is plastic.
thanks
thanks
Here are some neat connectors...http://www.hobbyengineering.com/SectionFR.html
Post Edited (Steve Joblin) : 3/20/2006 12:44:49 AM GMT
http://www.radioshack.com/product/index.jsp?productId=2104570&cp=2032062.2032398.2032404&pg=2&parentPage=family
I do not want the VEX STAMP. but I think the metal will work.
Although I feel like a traitor using VEX parts.
Post Edited (Special_K) : 3/20/2006 4:28:21 AM GMT
All the metal a robot builder could want:
http://www.vexlabs.com/
Kenny
Special_K, that RadioShack link you found sounds like a good deal (50% off).
I'm thinking of getting that myself, maybe.
For what it's worth, here are two more links:
www.budgetrobotics.com/shop/index.php?shop=1&cart=297137&cat=55&
www.budgetrobotics.com/shop/index.php?shop=1&cart=297137&cat=110&
Just one note RadioShack does not include a HEX key with the parts pack.
Post Edited (Special_K) : 3/21/2006 7:54:13 PM GMT
Nothing a multi-set of hex keys can't handle.
Plenty already crossing the VeX/BOE-Bot lines, making hybrids.
Stephen (gelfling6)
think I will name my next bot Fizzgig..
Do you have any links to sites that have Vex/BOE-Bot hybrids?
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
Did a quick look at the VEX page and noted they have a pneumatic cylinder kit.·OK, given that it appears you would have to pump up your robot with a bicycle pump to recharge the resevoir and design around the pneumatic cyclinder movement.· It also appears that the cylinder gets activated through a switch that is connected to the vex "brains" somewhere.·
Would a stamp be able to drive this switch?
The pneumatics would make one hell of a gripper!!!
When you CRUSH the middle of the first empty can you try to pick up, you may feel differently. A gripper should be able to grab an object gently and with a varying amount of side pressure. That might be a bit difficult or expensive using pneumatics. You'd need some kind of proportional air valve, and they can't come cheap!
Bruce Bates
<!--StartFragment -->
It's probably driven just like any air solenoid. +5V to activate the valve.
Still remember the gripper one of the FRL robots used, for the 2005 competitions,
had the following design:
\___|___/ when open.. /_|_\ closed.. to grab a tetra. all air solenoid & pneumatics.
was near impossible to dislodge the tetra, once it grabbed it, until it opened again.
I'd imagine, You'd have to make a simple transistor switch, powerful enough to drive the
air solenoid, and accept the TTL logic of the stamp.
Stephen (gelfling6)
