body parts — Parallax Forums
body parts
Special_KSpecial_K Posts: 162
edited 2006-05-25 22:14 in Robotics
Quick question: Does anyone have a Web link for metal robot body parts, i.e. metal with holes pre-drilled (in various shapes and sizes)·for construction of different styles of robot for use with the BOE or the BS2p24/40 Demo Board
, like·a four wheeled model? I have found a universal plate here
http://www.hobbyengineering.com/H2032.html
but I think it is plastic.
thanks
  • Steve JoblinSteve Joblin Posts: 784
    edited 2006-03-20 00:40
    check out the large home building stores (Home Depot, Lowes, Sears Hardware etc.) to see a great selection of connector plates (I think they are made by Simpson Strong-Tie)
    Here are some neat connectors...http://www.hobbyengineering.com/SectionFR.html
    Post Edited (Steve Joblin) : 3/20/2006 12:44:49 AM GMT
  • Special_KSpecial_K Posts: 162
    edited 2006-03-20 03:44
    I found this do you think it will work.
    http://www.radioshack.com/product/index.jsp?productId=2104570&cp=2032062.2032398.2032404&pg=2&parentPage=family
    I do not want the VEX STAMP. but I think the metal will work.
    Although I feel like a traitor using VEX parts.
    Post Edited (Special_K) : 3/20/2006 4:28:21 AM GMT
    edited 2006-03-20 15:38
    Have you checked out ebay for "erector set"? If these are the kinds of parts you are looking for, you might get more for your money on ebay!
  • Kenny GardnerKenny Gardner Posts: 169
    edited 2006-03-20 19:57
    All the metal a robot builder could want:
    http://www.vexlabs.com/
    Kenny
  • SciTech02SciTech02 Posts: 154
    edited 2006-03-20 22:19
    Also, try www.Lynxmotion.com.· There servo erector sets are very high quality, and come in all types of shapes.······· -SciTech02.
  • XNORXNOR Posts: 74
    edited 2006-03-20 22:59
    Special_K said...
    Special_K, that RadioShack link you found sounds like a good deal (50% off).
    I'm thinking of getting that myself, maybe.
    For what it's worth, here are two more links:
    www.budgetrobotics.com/shop/index.php?shop=1&cart=297137&cat=55&
    www.budgetrobotics.com/shop/index.php?shop=1&cart=297137&cat=110&
    edited 2006-03-21 03:50
    I got the VEX parts pack (at my local Radio Shack, with sale price) Mounted my BOE, Servo Controller, and two AA battery packs to a body I made (in 20 min).
    Just one note RadioShack does not include a HEX key with the parts pack.
    Post Edited (Special_K) : 3/21/2006 7:54:13 PM GMT
    edited 2006-03-23 04:05
    All the Radio Shack robot parts. VEX and BOE-Bot ar half off
  • gelfling6gelfling6 Posts: 60
    edited 2006-05-22 23:20
    Special_K said...
    Plenty already crossing the VeX/BOE-Bot lines, making hybrids.
    Stephen (gelfling6)
    edited 2006-05-23 02:42
    gelfling6... great name.
    think I will name my next bot Fizzgig..
    Do you have any links to sites that have Vex/BOE-Bot hybrids?
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2006-05-23 14:20
    The forums here have quite a few members (myself included) building bodies w/ VEX metal but using Parallax for the brains....
    Ryan
    Ryan Clarke
    RClarke@Parallax.com
  • Robert25Robert25 Posts: 53
    edited 2006-05-25 20:39
    Hi,,
    Did a quick look at the VEX page and noted they have a pneumatic cylinder kit.·OK, given that it appears you would have to pump up your robot with a bicycle pump to recharge the resevoir and design around the pneumatic cyclinder movement.· It also appears that the cylinder gets activated through a switch that is connected to the vex "brains" somewhere.·
    Would a stamp be able to drive this switch?
    The pneumatics would make one hell of a gripper!!!
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2006-05-25 21:05
    Robert25-
    When you CRUSH the middle of the first empty can you try to pick up, you may feel differently. A gripper should be able to grab an object gently and with a varying amount of side pressure. That might be a bit difficult or expensive using pneumatics. You'd need some kind of proportional air valve, and they can't come cheap!
    Bruce Bates
    <!--StartFragment -->
    Robert25 said...
    Hi,,
    Did a quick look at the VEX page and noted they have a pneumatic cylinder kit. OK, given that it appears you would have to pump up your robot with a bicycle pump to recharge the resevoir and design around the pneumatic cyclinder movement. It also appears that the cylinder gets activated through a switch that is connected to the vex "brains" somewhere.
    It's probably driven just like any air solenoid. +5V to activate the valve.
    Still remember the gripper one of the FRL robots used, for the 2005 competitions,
    had the following design:
    \___|___/ when open.. /_|_\ closed.. to grab a tetra. all air solenoid & pneumatics.
    was near impossible to dislodge the tetra, once it grabbed it, until it opened again.
    I'd imagine, You'd have to make a simple transistor switch, powerful enough to drive the
    air solenoid, and accept the TTL logic of the stamp.
    Stephen (gelfling6)
