You wouldn't mind to help me again on something???
Well hello,
I need a chip to convert serial asycronous data to parallel.·I need it for·cascading a LCD to my BS2.·I don't have the luxury to pay an extra 40$ at least on postage funds..... sorry...
Provas, Greece
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
Provas, Greece
-Rule your Destiny-
http://www.parallax.com/detail.asp?product_id=602-00009
http://www.semiconductors.philips.com/acrobat_download/datasheets/74HC_HCT595_4.pdf
You should be able to get these from a local dealer...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
it has also 8 additional I/O· pins for generic use.
hope this helps
Stefano Caruso
Provas, do a search on the term "serial backpack", it is the most frequently used term to describe what you want, and hopefully you can find someone in Greece who sells them, or a company in another EU member nation would have them and it may be cheaper to ship because of the economic arrangements.
1+1=10
Well I found somecircuits with Pic 16C57 or/and other microcontrollers. Is the use of a microcontroller nessessary? Isn't there a chip that can do that job. And if there isn't...·Do you know if I can find·a microcontroller pre-programmed·via Digikey?
Hope, not offending Parallax...
Thanks again, Provas, Greece
-Rule your Destiny-
