You wouldn't mind to help me again on something??? — Parallax Forums
Tricky NekroTricky Nekro Posts: 218
edited 2006-05-25 20:17 in General Discussion
Well hello,
I need a chip to convert serial asycronous data to parallel.·I need it for·cascading a LCD to my BS2.·I don't have the luxury to pay an extra 40$ at least on postage funds..... sorry...sad.gif
Provas, Greece
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
    edited 2006-05-25 14:33
  • BamseBamse Posts: 561
    edited 2006-05-25 15:00
    For just the serial to paralllell part, would a shift register do it for you ???
    http://www.parallax.com/detail.asp?product_id=602-00009
    http://www.semiconductors.philips.com/acrobat_download/datasheets/74HC_HCT595_4.pdf
    You should be able to get these from a local dealer...
    Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
    Experience level:
    [noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
    [noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
    [noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
    [noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
    [noparse][[/noparse] ] I dream in SX28 assembler...
    /Bamse
  • ellizardellizard Posts: 106
    edited 2006-05-25 15:27
    On the help page of the sx-key editor there is an example of a serial to parallel LCD converter working at 9600 baud based on an SX28,
    it has also 8 additional I/O· pins for generic use.
    hope this helps
    Stefano Caruso
    edited 2006-05-25 16:05
    If he's only using a single line (asynchronous) the shift registers wont work, a second clock pin is required.
    Provas, do a search on the term "serial backpack", it is the most frequently used term to describe what you want, and hopefully you can find someone in Greece who sells them, or a company in another EU member nation would have them and it may be cheaper to ship because of the economic arrangements.
    1+1=10
  • Tricky NekroTricky Nekro Posts: 218
    Thanks for the help.
    Well I found somecircuits with Pic 16C57 or/and other microcontrollers. Is the use of a microcontroller nessessary? Isn't there a chip that can do that job. And if there isn't...·Do you know if I can find·a microcontroller pre-programmed·via Digikey?
    Hope, not offending Parallax...
    Thanks again, Provas, Greece
    -Rule your Destiny-
