USB-Serial Adapter not working
Hi!
After not being able to get the DOS Editor to work, I decided to give another laptop a try (only USB present). I have a USB-Serial adapter which detects loopback and echo, but not the actual Stamp. The adapter is not much different from the Parallax one, except it terminates in a DB-25 Serial Port (I used a DB25-DB9 adapter on it). Are there any weirdnesses with DB25 serial ports?
Rafael
Rafael
Will check model later today etc...have stuff to do right now.
Rafael
Chris Savage
Parallax Tech Support
csavage@parallax.com
What protocol setting should I use (Xon/Xoff;hardware;none), if that has anything to do with it. I know it's not defective because a variety of mice and a modem work with it.
Rafael
Chris Savage
