USB-Serial Adapter not working — Parallax Forums
FlyingFishFingerFlyingFishFinger Posts: 461
edited 2006-05-21 00:10 in General Discussion
Hi!
After not being able to get the DOS Editor to work, I decided to give another laptop a try (only USB present). I have a USB-Serial adapter which detects loopback and echo, but not the actual Stamp. The adapter is not much different from the Parallax one, except it terminates in a DB-25 Serial Port (I used a DB25-DB9 adapter on it). Are there any weirdnesses with DB25 serial ports?
Rafael
  • ForrestForrest Posts: 1,341
    edited 2006-05-20 03:56
    What brand and model is the USB adapter?
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2006-05-20 16:43
    Still not working...I tried the latency thing.
    Will check model later today etc...have stuff to do right now.
    Rafael
    edited 2006-05-20 22:20
    Does it have a FIFO Buffer setting that you can turn off?
    csavage@parallax.com
    edited 2006-05-20 23:43
    In software you mean? Yes it does. I tried turning it off, but it still doesn't work.
    What protocol setting should I use (Xon/Xoff;hardware;none), if that has anything to do with it. I know it's not defective because a variety of mice and a modem work with it.
    Rafael
    edited 2006-05-21 00:09
    Unless the USB adapter has a FTDI chip in it or it's from Keyspan, the chances of it working with a Stamp are slim.
    My guess is it isn't compatible.· You never mentioned the brand but many aren't compatible due to lack of complete support of the serial protocol or poorly written drivers.
