Continuous Servo
I am having trouble using the continuous servos with Basic Stamp 2. I really cannot control them to go to the position I want them to go to. First of all they do not center. Whereever they are, they count it as the center. Secondly, I cannot send them to a specific position. They start turning and turning. So, I have no idea what to do with them. Maybe I should have a closed loop control for it. Any suggestions?
'{PBASIC 2.5}
'{STAMP BS2}
PULSOUT 12, 650
PULSOUT 13, 850
OS-X: because making Unix user-friendly was easier than debugging Windows
You will need to repeat the above, and note that the above will drive the servos to turn, not stop:
'{PBASIC 2.5} '{STAMP BS2} Here: PULSOUT 12, 750 PULSOUT 13, 750 PAUSE 20 goto HereIn reality the servos should be centered before doing anything with them:
'{PBASIC 2.5} '{STAMP BS2} Here: PULSOUT 12, 750 PULSOUT 13, 750 PAUSE 20 goto Hereat which point you adjust the POT until the servos are stopped.
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
Chris Savage
csavage@parallax.com
So many hobbies, So little time.......and money [noparse]:)[/noparse]
Ryan
Ryan Clarke
