Continuous Servo — Parallax Forums
Continuous Servo
HeshamHesham Posts: 2
edited 2006-05-17 15:16 in Robotics
I am having trouble using the continuous servos with Basic Stamp 2. I really cannot control them to go to the position I want them to go to. First of all they do not center. Whereever they are, they count it as the center. Secondly, I cannot send them to a specific position. They start turning and turning. So, I have no idea what to do with them. Maybe I should have a closed loop control for it. Any suggestions?
  • A.C. fishingA.C. fishing Posts: 262
    edited 2006-05-14 22:37
    Try
    '{PBASIC 2.5}
    '{STAMP BS2}
    PULSOUT 12, 650
    PULSOUT 13, 850
    Somebody said...
    -Never Underestimate the power of human stupidity.
  • HeshamHesham Posts: 2
    edited 2006-05-14 22:46
    I'll try it. I have the commands in a loop. That might be the reason. I used the code that was given in the manual. Thanks for the help.
  • SSteveSSteve Posts: 808
    edited 2006-05-15 00:58
    It sounds like you want standard servos not continuous servos. You can't move a continuous servo to a specific position. You can only make it rotate at different speeds (or stop).
    OS-X: because making Unix user-friendly was easier than debugging Windows
    edited 2006-05-15 17:27
    Yup, when a servo is "modified", so it becomes a "continuous rotation" servo, you lose the ability to command it to a certain position. That's what the "modification" does -- remove the hardware connection to the internal variable resistor, that provides the absolute positioning feedback.
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2006-05-16 15:38
    A.C. fishing said...
    Try
    '{PBASIC 2.5}
    '{STAMP BS2}
    PULSOUT 12, 650
    PULSOUT 13, 850
    You will need to repeat the above, and note that the above will drive the servos to turn, not stop:
    '{PBASIC 2.5}
    '{STAMP BS2}
    Here:
       PULSOUT 12, 750
       PULSOUT 13, 750
       PAUSE 20
    goto Here
    In reality the servos should be centered before doing anything with them:
    '{PBASIC 2.5}
    '{STAMP BS2}
    Here:
       PULSOUT 12, 750
       PULSOUT 13, 750
       PAUSE 20
    goto Here
    at which point you adjust the POT until the servos are stopped.
    Ryan
    Ryan Clarke
    RClarke@Parallax.com
  • AmaRobotDudeAmaRobotDude Posts: 14
    edited 2006-05-17 02:20
    I am just beginning my boe bot and was also wondering about the continuous rotation servos. Does 750 center the servos in the same location?
    edited 2006-05-17 03:39
    Technically on a continuous rotation servo it doesn't center at all.· It merely stops it (after calibration).· That is what centering is in that context.
    csavage@parallax.com
    edited 2006-05-17 04:34
    Oh, So its not really centering its just stopping it. I thought maybe if it stopped in the same location that could be used to make a servo go to spacific locations and use the continuous rotation at the same time. Thanks......Didnt mean to hijack the thread...... freaked.gif
    So many hobbies, So little time.......and money [noparse]:)[/noparse]
    You will often hear the term 'centering' even when talking about continuous rotation- the reason for this is the servo 'thinks' that it is centered when it gets the proper pulse signal (750 -> 1.5ms)- Even though the wheel stops (at an arbitrary position) it does so because it thinks that it is already at its center position.
    Ryan
    Ryan Clarke
