Overlapping bytemove/longmove/wordmove — Parallax Forums
rokickirokicki Posts: 1,000
edited 2006-05-17 04:18 in Propeller 1
If the regions pointed to by bytemove are overlapping, in either the
positive or negative direction, is bytemove still guaranteed to do the
right thing? Ditto for the other two. Thanks!
    edited 2006-05-16 21:33
    You bet! It figures out whether to do a forward or reverse move automatically.
    rokicki said...
    Chip Gracey
  • rokickirokicki Posts: 1,000
    edited 2006-05-16 21:41
    Great!
    I'm still confused by a few things though.
    If I have:
    var long curline, put
    what is the difference between the expressions
    byte[noparse][[/noparse]curline][noparse][[/noparse]put]
    and just
    curline[noparse][[/noparse]put] ?
    Also, the description of @@ makes me a bit concerned; it says if I have
    dat
    foo "baz", 0
    foo2 "baz2", 0
    bar long @foo, @foo2
    that I need to use @@bar[noparse][[/noparse]0] and @@bar instead of @bar[noparse][[/noparse]0] and @bar
    because the values in bar are not offset by the beginning of the data space.
    Can we get a clarification of exactly when we can expect the values to be
    so offset, and when we cannot? If I use
    x := @foo
    in a program, x gets the address of foo, so I don't need to use @@, right?
    So why doesn't it when I use
    dat
    bar long @foo
    Thanks for all the help!
    rokicki said...
    Great!
    If I have:
    Byte[noparse][[/noparse]curline][noparse][[/noparse]put] will access a byte pointed to by 'curline' with 'put' used as a byte·index. In other words, the byte will be located at the value of curline plus the value of put.
    and just
    Curline[noparse][[/noparse]put] will access the put'th long beginning at the address of curline. Curline is a long, so the index (put) will be shifted left by 2 bits.
    dat
    foo "baz", 0
    foo2 "baz2", 0
    x := @foo
    dat
    bar long @foo
    Okay. @@ is used to add the object's base address to some value, usually the address of something in a DAT section. Say you have a list of strings:
    DAT
    s1·· byte· "This is string 1.",0s2·· byte· "This is string 2. Bla Bla.",0s3·· byte· "This is string 3. Note these all have different lengths.",0s4·· byte· "This is string 4....",0
    stringtable word @s1,@s2,@s3,@s4· 'Here is a table of the string offsets within the object
    ...in a PUB/PRI you could access these strings as an array...
    · repeat i from 0 to 3
    ··· printstring(@@stringtable[noparse][[/noparse]i])
    ...printstring is some routine which wants the start address of some string in memory. Stringtable is a list of words which contains offsets of various strings. Stringtable[noparse][[/noparse]i] returns the offset of a particular string. The @@ operator adds the object's base address to give you the actual main memory address of string 'i'.
    Chip Gracey
