problem with downloading program
Ok, I switched to a new computer, downloaded and installed the drivers for my USB-serial adaptor (AirLink 101), then selected the correct COM port # for the Javelin IDE to download to.
When I turn on my javelin and click "program," it says "reseting javelin..." then as soon as it says "downloading" the terminal window shows up with messages indicating that the javelin is executing its code (the old program). It is like my javelin is sending messages to the terminal window WHILE it is trying to download the new program. Any suggestions?
http://forums.parallax.com/showthread.php?p=585022
Also, select only com1 to com4
regards peter
Best option is to have a serial port on your pc.
Second best option is to get the parallax usb2ser cable (has an FTDI chip)
that is guaranteed to work.
However, if it worked before with the same setup, can you try another javelin?
or at least disconnect anything from the javelin.
regards peter
For the benefit of others can you specify what adapter/drivers you are using, and which you had problems with?
Thanks.
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
I got my driver from here:
http://www.prolific.com.tw/eng/downloads.asp?ID=31
Which driver from that page did you use?
regard speter
regards peter
