MAX3232 with Propeller — Parallax Forums
SterlingSterling Posts: 51
edited 2006-05-08 03:46 in Propeller 1
I was looking over the Propstick schematics and it uses capacitors that are not polarized. So it doesn't matter whether you use polarized or non-polarized capacitors with the max3232, right? Is this true of any circuit... that you can use non-polarized caps in place of the polarized ones?
Which version of the max3232 does the Propstick use?
    edited 2006-05-08 03:26
    The PropSTICK currently uses the ST Micro version of the MAX3232, instead of the one made by Maxim. The use of non-polarized caps is an indirect consequence of the very high switching frequency used by these devices. This allows lower-value ceramic caps to be used in place of the higher-capacitance and more expensive tantalums or aluminum electrolytics.
  • SterlingSterling Posts: 51
    I just found your post about the MX3232 version you are using. Sorry about the duplicate question and thanks for the answer about the caps.
