Cheap servo extensions? Where? — Parallax Forums
bulkheadbulkhead Posts: 405
edited 2006-04-29 23:51 in General Discussion
Where can I purchase 10 or so servo extensions, at least 8" long for less than the $30 I am seeing at most places? That's quite a lot for some wire and connectors...any suggestions? Thanks.
    edited 2006-04-27 00:19
    How about these?
    http://www.parallax.com/detail.asp?product_id=805-00002,451-00303
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • bulkheadbulkhead Posts: 405
    edited 2006-04-27 01:41
    Wow, I searched "servo extension" but it didn't come up. That's just what I was looking for! Thanks Chris.
  • Vern GranerVern Graner Posts: 337
    edited 2006-04-28 23:54
    bulkhead said...
    Those are Female to Female, I think for servo *extensions*, you need male to female...?
    Vern
    Vern Graner CNE/CNA/SSE    | "If the network is down, then you're
    Senior Systems Engineer    | obviously incompetent so why are we
    Texas Information Services | paying you? Of course,if the network
    http://www.txis.com        | is up, then we obviously don't need
    Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
    edited 2006-04-29 00:13
    There is a male to male adapter (3 pin SIP post header) included that will let you change the gender of one of the female ends.
    Beau Schwabe
    IC Layout Engineer
  • RDL2004RDL2004 Posts: 2,554
    edited 2006-04-29 21:18
    Hello Bulkhead,
    It's really not that hard to make your own connector cables and it's a great skill to have. I can't tell from the previous posts if you need 0.1 or 0.156 or what, but solderless crimp-type connectors are pretty much all the same as far as how hard they are to make. Here is a post I made to help people get started:
    http://forums.parallax.com/showthread.php?p=577638
    ... of course, if all you need is one or two, and you can buy exactly what you need, I highly recommend just buying them, because making them will be more trouble than it's worth.
    - Rick
    Edit:
    for more info, search with Google on
    "how to crimp"
    (with the parenthesis)
    I can post more pics if you need.
    Post Edited (RDL2004) : 4/29/2006 9:37:34 PM GMT
    Yeah, I already ordered 10 of these from parallax. I would make it myself but it just won't turn out as good as premade ones. The last thing I want is another possible problem spot on my robot- it would be one more thing to go wrong. I would probably still buy them at $3 each because I really need them, and am pressed for time to get this project finished and working (well). These just happen to be cheaper so I ordered a few extra. I'm going to cut some in half to make touch sensors for my robot. At $.50 for the half extension and $1 per switch, these sensors will be cheap, reliable, and easy to make.
    I'm not sure if I need .1 or .156, but it is the kind that servos use. I hope I got the right ones.
