Cyclone 100 FastPack with parallax example code.
Clock Loop
I know this is quite old, but I have a problem with getting the parallax example code to work with.
My cyclone is the ep1c3t100c7, the one on the parallax fastpack.
Here is the Quartus II output I have the latest version of QuartusII
When I open the parallax example file, it gives me an error that I am loading an old file and that it will be converted to the newer quartus version.
I then get these errors.
Info: Converted project /EP1C3 -Fastpack/top.quartus to the new Quartus II software file format. Using newly created Quartus II Project File /EP1C3 -Fastpack/top.qpf and Quartus Settings File in place of all old project files (with extensions .quartus, .psf, .csf, .ssf, .fsf, .esf).
Info: Can't convert assignments -- the following assignments contain errors and were not imported to the converted project
Info: /ep1c3 -fastpack/top.csf
Info: set_parameter -name RESERVE_NCSO_AFTER_CONFIGURATION OFF
Info: set_parameter -name RESERVE_NCSO_AFTER_CONFIGURATION OFF -section_id top
Info: set_parameter -name SIGNALPROBE_AUTO_ASSIGN 0
Info: set_parameter -name SIGNALPROBE_COMPILATION OFF
Info: set_parameter -name SIGNALPROBE_ROUTING ALL_SIGNAL_PROBE
Info: set_parameter -name ADV_NETLIST_OPT_FIT_LE_DUPLICATION_WITH_LUT_RESYNTH OFF
How do I fix them?
Meh. Nothing here, move along.
How do I fix them?
