Stamp module.breadboard
hello
is it safe to install a basic stamp 2 ic module into a breadboard without a socket
any input would be appreciated
japer
japer
i should clarify a solderless bread board, sorry
japer
my way of doing it is to take a small screw driver with some tape on the end and prey it a little on one side and then the other and slowly work it out. but also keep in mind that there are traces on the bottom of the BS2 that are part of its circuit, you scratch one of them and is most likely game over
thank you
japer
