That's a loaded question.· The limits of communication and the limits of sustained throughput are two different things with a BASIC Stamp which doesn't have a FIFO buffer or hardware UART.· Formatters used in the SERIN command can also limit receive speed of large packets of data.· This would be like sending command bytes and getting back small packet responses.· So you see, there are many factors to consider.· Generally the BS2 can do 38.4Kbps for general command byte style communication.· ASCII strings and packets of data work usually up to around 9600 bps if you're not using a lot of formatters in the SERIN command.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
The BS2 can transmit (SEROUT) up to about 50K baud (SERIN has limits if you want text-to-numeric conversion) -- if you have a good connection between point A and point B. If you connection is garbage, a lower baud rate will be more forgiving; that said, ALWAYS make the best connections you can (don't try to fix hardware problems with software).
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Chris Savage
Jon Williams
