trying to send data from matlab to basic stamp editor and viceversa
Hi,
I am trying to send data from matlab to basic stamp editor and viceversa.
I'd like to know if there is any method by which I can directly write the incoming data onto the EEPROM of basic stamp?
Also,how can I check if my data that has been sent out from matlab being read at the basic stamp?
Right now am using the SERIN command---
DEBUG "before"
SERIN 16,240,[noparse][[/noparse]dec data]
DEBUG "after"
and on running my stamp(after the matlab,for sending data),stamp does not read the SERIN line ....that is here only "before" appears in the debug terminal.
What is the ideal way of programming for reading from serial port?Please suggest.
Gayatri.
I have been referring to the attached document for syntax commands.
Post Edited By Moderator (Chris Savage (Parallax)) : 4/19/2006 6:11:41 AM GMT
DEBUG "before"
DEBUG "after"
Gayatri.
· You can WRITE DATA (received from some source serially or the results of calculations internal, etc.) to the STAMP's un-used addresses when it is running its program.· This derived DATA cannot be·read using the PBASIC IDE (editor) per se.· It can only be read by the STAMP itself as part of its program, and then displayed on an LCD or by using DEBUG.
· Study the use of READ, WRITE, and DATA in PBASIC Help.
