How do I Verfify LCD Terminal AppModule is Okay
LoopyByteloose
Well, I have almost completed the physical construction on my HP Printer contest entry, but I may have damaged my LCD Terminal AppModule.
As usual I had Vss and Vdd mixed up and things got awful hot.· Since I was holding on to the board I noticed right way. The BS2p40 just about burnt my thumb.
I am using the BS2P24/40 demo board and have gotten it all correctly wired now.
To verify system integrity, I wanted to get the LCD going.
I have the other LCD port working fine and will leave it on overnight to see if anything is wrong.
But, the little LCD doesn't seem to want to respond.· I know I am suppose to shift to Pin 8 [noparse][[/noparse]or 9] to get output.· That doesn't seem to help.· It may be that I just have missed something in code OR it may be real damage.
I would prefer to use that board because it has ample menu and I need the 4 input buttons.
·· Refer to the·example code in the documentation for this unit.· Remove whatever might interfere and try just the AppMod.· See if it works then.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I wrote this pretty much in a late night·panic.· But by starting over and locating the LCD docs, I find that the LCD is a-okay.· I removed all the wiring, determined PIN 1 [noparse][[/noparse]not PIN 8] was the enable, and tested it over night.·
Is anyone else actively working on the H/P Printer contest?· The printer controller board with the SX-28 can easily be adapted to other uses and has a USB interface.· It makes the whole package a very good value.
