SX Video Module Questions
lots and lots of questions:
Can this be programmed just by a BS2?
If not, will an SX keychain work?
Can I download graphics from my computer to it?
If not, do I have to use code to make the graphics? How?
I really liked the looks of the Amulet LCD, but it is discontinued. Can anyone suggest a simple LCD that is just the next step up from Parallax's? Something like the Amulet.
Thanks everyone?
A.C. fishing
Thanks everyone?
A.C. fishing
As I understand it the SX Video Module is to create low resolution characters and graphics on a T.V. or video monitor.
I believe that you can start out by using the BasicStamp·to program and interface it to other devices.
It would be·quite useful for something where you wanted to overlay text onto a video image -- like a time stamp or to silently broadcast local information over a net of monitors.· You might be able to play a game such as PONG by programing into the BasicStamp.
You expectations seem to be more in line with the new Propeller Chip and the Hydra video that will be coming out soon. And they will knock your socks off. Higher resolution, color, and much more.
The chip along is about the same price.· The Hydra is a whole different story, but WOW!
They will be taking orders for chips on Monday.
Post Edited (Kramer) : 4/1/2006 12:32:52 PM GMT
What is an approximate Hydra price?
I'm eager
All under your programing control! My guess is that it will be under $200 as Mouser has it already listed as such.
Why would you want an LCD for output? Kinda of like hamburger versus steak.
Sorry, but I buy local Taiwanese LCDs off the shelf.
The Propeller can do must the same as the Hydra and/or LCD, but you have to wire it to do so.
It is merely the 40 pin DIP at the core of the Hydra's design.
Maybe, you should jump over to the Propeller Forum and catch up.
SEROUT SPin,Baud,[noparse][[/noparse]v_PlotXY,X,Y]
To describe the point of a pixel. Will the hydra work this way?
Will it be able to be programmed from the BS2?
Will it support color?
As i asked about the Video Module, will you be able to download a BMP file to it?
ALL IN ALL, where can I find out more???
Any serial LCD should work fine. I have gotten a Scott Edwards and a G12032 graphics LCD to work just fine using the Propeller, thanks to Martin Hebel's BS2 Functions. Parallel LCD's can be done as well, but I have not done this yet.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
www.sxvm.com
But I what I mean is I want a high quality LCD for the project.
All under your programing control! My guess is that it will be under $200 as Mouser has it already listed as such.<<
I think you've got the Hydra and the Propeller demo board confused with one another. Mouser has a listing on the Propeller demo board with mouse, keyboard and VGA ports.
The Hydra is Andre's project and it's not quite finished yet - see here for more info 205.158.110.70/ubbcgi/ultimatebb.cgi?ubb=get_topic&f=20&t=001322
The SX-Video module is open-source. If you have an SX-Blitz or SX-Key you can define your own characters bit-maps.
No you cannot "load" a BMP into it. It is strickly black and white output. If you redefined all the characters you could display an image of 128(h) x 48(v) pixels.
What exactly is it you're trying to do ?
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
I have created a software that turns each frame in a SWF file into YX of each pixel.
Then those pixels will go down a USB(I perfer USB to Serial) cord, hook up to a device, the action script will be converted to PBASIC, or SX launguage, or Spin, and go to the device also, and will be shown on the screen, and the Flash game/movie will play on the screen. The same action script used for the keyboard commands will be converted into whatever launguage I'll use and work instead on the buttons on the device. In short, a portable Flash Player. The Player then can be rehooked up and the software on it loaded. As for the long process of converting the code, we must remember that compared to C++,BASIC, or HTML the main codes used in actionscript are very limited.
Those who use Flash will greatly appreciate it.
-Software has always been easier for me...
Chris Savage
Parallax Tech Support
csavage@parallax.com
· You are definately out of the league of the SX-Video module.
· You might check out this color LCD http://www.sparkfun.com/commerce/product_info.php?products_id=569
Bean.
Bean.
Sorry for the crumby picture...
Bean.
Are you willing to help a noob with a little palm slap on the forehead troubleshooting? I'm now have both the LCD and carrier board from Spark Fun. I got a 3.3 volt regulator and the 10K resistors setup and verified with a voltmeter that they are connected properly.
Loaded your code into my Board of Education with a BS2 stamp but nothing but the LED backlights? Is there some significant timing differences in the code for a BS2 vs BS2p?
I did build a pretty neat little edge card to plug it into the proto area.
Any tips or suggestions?
Ken
P.S.
Ooops, never mind. I had a broken trace on the back of the carrier board. Once fixed every thing works great! I see what you mean about recommending one of the faster stamps. Watching it draw row by row!
Post Edited (Ken Purcell) : 4/22/2006 4:25:42 AM GMT
Glad you got it figured out. It is cool little LCD display.
Let us know if you do something cool with it.
Bean.
"SX-Video OSD module"·available·for only·$49.95·www.sxvm.com
I certainly like to thank Bean for the source code. I had ordered the Color LCD screen from Spark Fun over a month ago and was waiting for their carrier boards to be back in stock. Soldering those .5 mm pins wasn't something I was gonna try.
Now to put a face on this Bot.
Ken
· Not to make you jealous, but I have successfully used the SX chip to put some 130x130 4096 color images on the display. Very cool.
· I wish I had more time, I'd think about making a serial driver board that that LCD (using an SX).
Sterling,
· I suspect it is because it is not RoHS complient. A new version is being built that is RoHS complient.
· I don't think it was a big seller for Parallax anyway.
· The new version WILL be available from me very soon (2 weeks).
Bean.
Post Edited (Bean (Hitt Consulting)) : 4/25/2006 6:48:23 PM GMT
