Making Autonomous Electric Ridein/Gocart Car
Well I had many crazy projects during the days, and I have another one that is less crazy.
I thought I will start from the bottom, after assembling and dissembling like 10 times, I got bored of
Playing with a little Autonomous robot.
··· I thought why not transform that into an Autonomous Electric Ridein/Gocart Car.
First I thought if I could build a battery circuit I could be able to pull it off.
But then I don’t know how to build a battery circuit. Also I need wire extender for the 2 sensors (PING))) ™ Ultrasonic Sensor) which can see up to 9feet. One added to the left, the other to the right. Plainly the same codes as the ir navigation code.
All I need to know is how to make a Battery circuit for a ride in car, and if I could get this project done I could innovate from there.
Happy new year
Happy new year
A charger circuit?
What kind of batteries are you going to use? What are they rated for (voltage/current/Amp-hour)?
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
And do you know where i can·buy a Inertial measurement unit?
Happy new year
Also, for anything highly advance and powerful for things like the Darpa challenge, I would recommend Freescales 32-bit processors for that application. (some are over 1GHz in speed for the PowerPC models). www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=0162468rH3&tid=FSH or if that doesnt work, use: www.freescale.com/ for the main page and click on the 32-bit's.
I watch how the moon sits in the sky on a dark night,
shining with the light from the sun,
The sun doesn't give light to the moon,
Assuming the moons gonna owe it one,
Post Edited (ShadowDragon) : 4/3/2006 6:30:44 PM GMT
· You were right about that ultasonic.
Happy new year
Geez, just by the sounds of it, it'd be expensive.· Of course, you could probably figure out a suitable arrangment of accellerometers that would give you the information you are after!
There's been a couple of "balancing robots" that can stay upright on two wheels using just an accellerometer....
And again you didn't answer what you wanted in a battery circuit!?· Are you looking for a charger?· What "TYPE" of battery is it? (gel cell, lead-acid, AGL?, or something else?)· The material that makes up the battery helps determine what kind of charging it can take.
Once again, the more information you provide in your request, the better someone on the forum can help!
Steve
Website: http://www.batbot.whitelightercentral.com. Well the reason why I don’t need the battery circuit is that am getting sponsored from a go-kart company, well I still need the battery circuit but not now.
Since the Darpa Grand challenge 2006 already started, I am looking forward for 07.
Please visit: http://www.batbot.whitelightercentral.com
I am also recruiting people to join my team, remember grand prize is 2million (not that I need it).
YES
Happy new year
Post Edited (Batman) : 4/5/2006 6:02:08 PM GMT
Happy new year
Steve
Wonder what are the thoughts of the Legal Dept. at DC Comics.
When you get 1st Place in the "Darwin Awards", you're a Winner & a Loser.
And Parallax.....
The software has 5 programmed paths. Then when I click create path. It randomly selects one, and as it moves that character from point·A to Point B it moves my·boebot as well. This is pretty simple.
Happy new year
Server: irc.whitelightercentral.com
then join room #charmed and #programming
Website: http://www.batbot.whitelightercentral.com/
Still workin on my codes.
Happy new year
The other 1% is the software.· Hardware builds itself.
...I wonder what XBox360 thinks about his website, also.· www.xbox360.com
Post Edited (Steel) : 4/20/2006 6:10:55 PM GMT
