Making a STAMP powered Go-Kart
·how could a stamp power some 20 horsepower motors? (For a Go-Kart)
Can anyone suggest any motors for the project?
thanks
thanks
http://www.parallax.com/detail.asp?product_id=29144
Jon Williams
Jon Williams
I'm using this schematic. The path splits, and goes to the two switchs. until the switchs are turned on, the path continues through the LEDs and to the end. When the switchs are on the path goes the alternate route and to the end. I want each switch toONLY affect one of the LEDs, but when one switch is pressed, both LEDs go off.
How can I solve this problem??
or 175 ft-lbs of torque.
To get anywhere close to those figures you have to look for specially made motors for electric vehicles. The closest I could find easily is the Briggs and Straton Etek motor with a max 20 hp (8 hp continuous) which runs on 12-48 V (8 hp @ 48V), with no load current of 6A and 160 ft-in (13 ft-lbs) load current of 160A, for the low low price of $695 apeice. Needless to say you couldnt use the HB25 controller on it.
Jon has much more experience with go karts (Ive never owned one), but trying to make an electric go kart seems like a very expensive proposition. But perhaps someone with more experience in this type of thing would be able to point you in a cheaper and more viable direction.
<edit> Looking at some golf cart motors, I found an 11.4 hp motor when run at 48V for $479 and requires a 400+ amp controller here: http://www.cartszone.com/clubcarmotors.html·</edit>
·1+1=10
Post Edited (Paul Baker) : 3/28/2006 9:18:40 PM GMT
Jon Williams
and I won't need it to go far.
Now for the answer to the second question
Can you define "not far"?
I suspect 20 horsepower on batteries (forget the solar panels; in a short run they'll be more hindrance than help) is about 20 feet, unless the batteries are large.
Really, you need to rethink the physics of your proposal....... it's just not practical without spending a LOT of money on exotic battery and controller technologies. Sorry to disappoint you, but truly not realistic.
Cheers,
Peter (pjv)
http://www.arnoldsgokarts.com/
Brian
There's nothing a good wack with a hammer won't fix
Darn I let the white smoke out again
After all, that would really challenge people to look at the balance between battery, controller, and motor.
In order to level the playing field, entries could be by a weight class and/or a motor size.
In a weight class, every one except the heaviest of contestants would add on-board weight to equalize the actual body weight to the heaviest person. Cars would not actually weigh the same, but the drivers would be effectively the same weight.
Isn't that what they do in horse racing with the jockey and saddle?
Motor classes would take a bit more figuring.
