Making a STAMP powered Go-Kart — Parallax Forums
A.C. fishingA.C. fishing Posts: 262
edited 2006-03-29 12:11 in General Discussion
·how could a stamp power some 20 horsepower motors? (For a Go-Kart)
Can anyone suggest any motors for the project?
thanks
    edited 2006-03-27 23:24
    Have you seen the HB25 motor controller?· You'll have to compare your motor specs against what it will handle, but it might just be the ticket.
    http://www.parallax.com/detail.asp?product_id=29144
    Jon Williams
  • A.C. fishingA.C. fishing Posts: 262
    edited 2006-03-27 23:47
    YES! will I need one for each motor?
    edited 2006-03-28 00:07
    That would deliver the most power, yes; it might even help with turning if you changed motor speed in turns -- but that adds overhead to the software and requires feedback from the steering wheel. If your go-kart (I used to race Yamaha clutch class) has a solid rear axle, you could use one motor connected to the axle with a chain or belt.
    Jon Williams
    edited 2006-03-28 20:24
    Can you suggest any motors?
    edited 2006-03-28 20:56
    Another bit off-topic question that I don't want to make another post for:
    I'm using this schematic. The path splits, and goes to the two switchs. until the switchs are turned on, the path continues through the LEDs and to the end. When the switchs are on the path goes the alternate route and to the end. I want each switch toONLY affect one of the LEDs, but when one switch is pressed, both LEDs go off.
    How can I solve this problem??
    edited 2006-03-28 21:08
    Your going to have an extremely hard time to find a DC motor to fit your specs. Lets assume you want a top speed of 10 mph, that is 15 ft/s. Assuming you use wheels that are 6" in diameter, each rotation of the wheel will cover 1.5 ft, so to reach the 15 ft/s the motors have to spin at 10 rps or 600 rpm. To find the associated torque of a 20 hp motor spinning at 600 rpm we use:
    or 175 ft-lbs of torque.
    To get anywhere close to those figures you have to look for specially made motors for electric vehicles. The closest I could find easily is the Briggs and Straton Etek motor with a max 20 hp (8 hp continuous) which runs on 12-48 V (8 hp @ 48V), with no load current of 6A and 160 ft-in (13 ft-lbs) load current of 160A, for the low low price of $695 apeice. Needless to say you couldnt use the HB25 controller on it.
    Jon has much more experience with go karts (Ive never owned one), but trying to make an electric go kart seems like a very expensive proposition. But perhaps someone with more experience in this type of thing would be able to point you in a cheaper and more viable direction.
    <edit> Looking at some golf cart motors, I found an 11.4 hp motor when run at 48V for $479 and requires a 400+ amp controller here: http://www.cartszone.com/clubcarmotors.html·</edit>
    ·1+1=10
    Post Edited (Paul Baker) : 3/28/2006 9:18:40 PM GMT
    edited 2006-03-28 22:02
    The biggest issue is carrying around the fuel -- it seems to me the batteries required to power a kart that could move a human would outweigh everything else. If one looks at a golf cart, for exaple, the entire compartment under the seat is filled with 12 batteries.
    Jon Williams
    edited 2006-03-29 01:18
    Jon Williams said...
    I was thinking about·a solar panels plus some batteries.
  • pjvpjv Posts: 1,903
    edited 2006-03-29 05:03
    Hi AC
    Can you define "not far"?
    I suspect 20 horsepower on batteries (forget the solar panels; in a short run they'll be more hindrance than help) is about 20 feet, unless the batteries are large.
    Really, you need to rethink the physics of your proposal....... it's just not practical without spending a LOT of money on exotic battery and controller technologies. Sorry to disappoint you, but truly not realistic.
    Cheers,
    Peter (pjv)
  • Washer MedicWasher Medic Posts: 39
    edited 2006-03-29 05:29
    Hi check out what my neighbor is doing with this very subject they are a blast but don’t last long on a charge thoe
    http://www.arnoldsgokarts.com/
    Brian
    There's nothing a good wack with a hammer won't fix
    Darn I let the white smoke out again
    edited 2006-03-29 06:44
    You could have electric go-cart drag races.
    After all, that would really challenge people to look at the balance between battery, controller, and motor.
    In order to level the playing field, entries could be by a weight class and/or a motor size.
    In a weight class, every one except the heaviest of contestants would add on-board weight to equalize the actual body weight to the heaviest person. Cars would not actually weigh the same, but the drivers would be effectively the same weight.
    Isn't that what they do in horse racing with the jockey and saddle?
    Motor classes would take a bit more figuring.
    Thanks! I will reconsider and go a bit more in-depth
