Compact Flash Memory
I'm working on a prototype application that requires a large (relative to STAMP EEPROM standards) amount of storage to store a database of key-value pairs (numeric). I'll need to be able to add records, modify records, search them (binary tree) and delete them. I figure the best way to handle this is to interface the Stamp to a compact flash memory card.
Has anyone tried this?
Todd
Rogue Robotics has two items that might fit this need. First they have a module I've used called the uMP3:
In some of my projects I've used it to record data to SD/MMC cards from a Basic Stamp. The card is formatted Fat32 so reading it with a PC is easy. Rogue also sells uMMC module that uses SD/MMC cards too:
Where the uMP3 has both data and sound capabilities, the uMMC is data only.
The uMP3 retails for $99.00 Canadian (that works out to $85.50 usd)
The uMMC retails for $49.99 Canadian (that works out to $42.74 usd)
Details on the uMP3 are here and details on the uMMC are here. Hope this helps.
Vern
Are these guys still around? when I tried the link above, I got this:
Update: I did some digging (well, "googling") and found a site that sells the item:
http://www.saelig.com
The ALFAT seems to have SD-MMC, CF and IDE capabilities. It sells on that site for $89.00 I still can't get to the "www.ghielectronics.com" parent site though...
Vern
Post Edited (Vern) : 3/28/2006 1:29:41 AM GMT
·1+1=10
