Parallax USB Oscilloscope - 40-volt attenuation feature — Parallax Forums
Mike CookMike Cook Posts: 829
edited 2006-03-27 18:16 in General Discussion
I was looking through the help file in the current Parallax USB Oscilloscope software (4.0). Is this just out dated information or is it supported? If it's supported where can I find info on this circuit. Clicking on the link 'Optimum Designs Inc.' takes you to the Parallax USB Oscilloscope page.
"The 40-volt attenuation feature requires additional hardware between the OPTAscope and the probes. This circuitry can be purchased from Optimum Designs Inc."
Also noticed the 4 pin SX header (J1)·inside the scope. Is the current firmware for this scope still 2.0.7?
·attachment.php?attachmentid=40965
"OEM NMEA GPS Module" Now available on ebay for only $17.49
http://www.allsurplus.net/Axiom/
Post Edited (Mike Cook) : 3/24/2006 10:55:26 PM GMT
  • Paul Sr.Paul Sr. Posts: 435
    edited 2006-03-24 23:17
    Mike Cook said...
    Also noticed the 4 pin SX header (J1) inside the scope. Is the current firmware for this scope still 2.0.7?
    Your not supposed to show it's guts like that here.....
    edited 2006-03-24 23:19
  • Doug PientakDoug Pientak Posts: 16
    edited 2006-03-27 18:14
    Hello,
    The 40V hardware was never developed and the comment in the software was to be removed.· How ever you can use this feature by adding a 1M ohm resistor in series with the oscilloscope probe.·
    2.0.7 is the latest firmware for the hardware.··No·updates.·
    I hope this answers your questions.·
    Doug Pientak
    Parallax Engineering
    Thanks Doug!
