Parallax USB Oscilloscope - 40-volt attenuation feature
Mike Cook
I was looking through the help file in the current Parallax USB Oscilloscope software (4.0). Is this just out dated information or is it supported? If it's supported where can I find info on this circuit. Clicking on the link 'Optimum Designs Inc.' takes you to the Parallax USB Oscilloscope page.
"The 40-volt attenuation feature requires additional hardware between the OPTAscope and the probes. This circuitry can be purchased from Optimum Designs Inc."
Also noticed the 4 pin SX header (J1)·inside the scope. Is the current firmware for this scope still 2.0.7?
"OEM NMEA GPS Module" Now available on ebay for only $17.49
http://www.allsurplus.net/Axiom/
Post Edited (Mike Cook) : 3/24/2006 10:55:26 PM GMT
Your not supposed to show it's guts like that here.....
The 40V hardware was never developed and the comment in the software was to be removed.· How ever you can use this feature by adding a 1M ohm resistor in series with the oscilloscope probe.·
2.0.7 is the latest firmware for the hardware.··No·updates.·
I hope this answers your questions.·
Doug Pientak
Parallax Engineering
