LCD -- 8 rows x 21 cols; serial. Photos!
Saw these at ebay, LCDs, 8 rows (lines) x 21 columns [noparse][[/noparse]for 168 characters] --
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7594533325&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Post Edited (PJ Allen) : 4/22/2006 8:51:07 PM GMT
I can't make out the SIZE of the LCD. And without that, well...
Don't visit my new website...
· (I think the connector at the top is 0.1in spacing, you could judge against that, too.)
· Finally found the time to put together the LCD serial backpack for it.· They send you the components and a protoboard (it's NOT a pcb.)· Instead of their grid-holes protoboard, I Dremel'd out a piece of IC-pattern board.
· I'll have to see if I can borrow a friend's camera (my video-stills are too fuzzy for this.)
· In the meantime, here's a program that I made to check·it out.
· I found on my own that the sequences for DISPLAY CLEAR and envoking NORMAL or REVERSE display modes need a PAUSE before going on with Text functions (when all else fails, start placing PAUSEs between instructions.)
· Another thing I need to find out is which of the two pins connected to +5V is for the LED backlight.
· [noparse][[/noparse]By the way, on my backpack·I set up a 78L05,·and so·power it from "VIN"and not VDD.· If not for the backlight VDD might suffice, but I'd probably do it this way anyway.]
BTW, that vise in the picture, I think that is one thing no one can be without. Did you get the PCB holder for it?
Bean
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available·for only·$49.95·www.sxvm.com
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
