Parallax Tri-Axis Accelerometer Module
From the information on the web, I find that the·SPI communication uses 3 pins only.
They are /CS, CLK and DIO. The DIO pin is bi-directional.·It mentioned that requiring the CLK and DIO pins may be shared in systems requiring the use of more than one H48C module. It seems to me this configuration is·daisy chain. From the datasheet of MCP3204, it does not mention whether it supports daisy chain or not ? Can anyone tell me how the serial communication in the Parallax Tri-Axis Accelerometer Module work ??
Post Edited (James2006) : 3/16/2006 10:58:51 AM GMT
They are /CS, CLK and DIO. The DIO pin is bi-directional.·It mentioned that requiring the CLK and DIO pins may be shared in systems requiring the use of more than one H48C module. It seems to me this configuration is·daisy chain. From the datasheet of MCP3204, it does not mention whether it supports daisy chain or not ? Can anyone tell me how the serial communication in the Parallax Tri-Axis Accelerometer Module work ??Post Edited (James2006) : 3/16/2006 10:58:51 AM GMT
Jon Williams
