Trying to Identify An LCD Backpack
Received an LCD 2x16 Characters with no datasheet.· The LCD itself is a 16pin soldered to a "backpack" utilizing a PIC16F876-20/SP.· Trying to
figure out the pin assignments so I can use it in a Stamp Project. Can anyone recognize this.· Thanks
The only true way you can identify the lcd, is to take the board the pic is sitting on off of the lcd board, so the lcd chips and layout can be looked at. Once you identify the lcd controller chip, you can then get a datasheet on the controller chip and read it to understand how to get the lcd to do stuff.
Take the circuit board the PIC is attached to off of the lcd board. Then upload the picture here if you still can't identify it.
Meh. Nothing here, move along.
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
