LED Matrix Display Drivers (5x7)?
Does anyone suggest drivers for five LED Matrix Displays?
Here is a link to the LED Matrix components:
http://rocky.digikey.com/WebLib/Lite-on/Web%20Data/LTP-747KR.pdf
My end goal is to have an intresting clock display for my desktop.
Ideas or suggestions?
0011010000110010
Nitrohawk
0011010000110010
Nitrohawk
Jon Williams
What we do without you?! This is exactly what I was looking for. I guess if I have a whole mess of them (5x7 LED Matrix) I would have to buy a MAX7219 for each display?
I admit, I just scanned your Nuts & Volts... Going to print it out and take home to read tonight.
Thanks!
0011010000110010
Nitrohawk
Jon Williams
Works great - I can turn on a single LED, turn on two LEDs with different ON times (deparature and destination) or flash all 64 in a random pattern.
It takes 3 Stamp I/O lines for 64 LEDs.· With two more 595s and one more Stamp I/O line I could run 128.· The 64 LEDs indicate the airports I use in Flight Simulator from Burlington, VT, to San Diego.
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
Jon Williams
(I just got mine in today... I can't wait till the NEW laptop arrives...)
KK
Just tossing my two bits worth into the bit bucket
KK
I also have some LTP747 from Jameco which I beleive are common Anode and Jon's circuit calls for common Cathode so the 5x7 is actually a 7x5 dot matrix display - depending on how you look at it. I have attached·some modified versions of his circuit which uses the LTP747 for you to study. It does not use the joystick functionality.
Thanks.
Thanks.
Thanks a bunch. I will have to check these out and see how I might be able to glean some of your wisdom.
0011010000110010
Nitrohawk
