How to Connect a Stamp to a PC Monitor?
Any Ideas??
I have a few spare 15" 640x480 Monitors lying around, and im wonding if it is possible to use them in a simular way to an LCD screen, i have a BS2 and a BS2p-40 and would prefer to use the BS2, but if thats not possible then the other 1 is also fine
Thanks People
Sam
Thanks People
Sam
Parallax sells two of my video modules. These are NOT for VGA monitors but are for regular TV inputs (RCA jacks). They are strickly black and white output. The cheaper one is video output only and displays 6 lines of 16 characters (it has sound output also). The more expensive one does video overlay and displays 8 lines of 24 characters, but does not have sound.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
http://www.dontronics.com/micro-vga.html·sells a variety of VGA controller cores (so you can choose the resolution you want), and provides 3 types of interface board to plug the core into. You likely want the TTL to VGA board.
Be sure before purchasing the unit it has an onboard video display memory, otherwise it wont work with a stamp (again stamp isn't fast enough to supply all the data nessesary for unbuffered driving)
·1+1=10
Post Edited (Paul Baker) : 2/4/2006 3:08:13 PM GMT
I have one of these and have used it to pipe video from the television and from game consoles onto my PC monitor.
I wonder if this wire is hot...
Bean.
Brilliant!
Why didn't I think of it?
Seriously though, sometimes it's nice to put up the output of an SX or a BS on a screen so you can see what's going on.
The StampDAQ application that comes with the Flexiforce demo is an excellent example of this.
My current project is an SX28 driving an 8-segment display through the MAX7219.
It also has an analog to digital converter, a dial potentiometer, and a whole host of headers for miscellaneous input and output.
I am building it so I can observe certain calculated parameters in real time.
One obvious application is to get a readout of the signal to noise ratio of a detector by digitizing its output and observing how many digits are stable on the display.
