Broken Pin Repair - BS2
Well, of course, eventually a student breaks a pin on their BS2. This one is P24, Vin. It partially seats in the socket, but really needs repair. Is there available a fix-it kit, or can someone point me to a source to find the necessary pin hardware to do the job? Since they are a little offset from the board pin, I can't really use a machine pin to replace it.
Jim
Jim
Capital suggestion! Works fine, not hard to do. I'm thinking it might be a good idea to seat ALL the stamps in a quality socket, the machine pins of the socket make it much easier to in and out the things.
Thanks again,
Jim
When I first started out I did what Pj Allen has described with other IC's I had.
BTW) Wire wrap sockets work well for this kind of application. I guess you could call these "machine pin type"
Beau Schwabe
IC Layout Engineer
"antenna" effect? Or not a problem at STAMP speeds...
Jim
