Broken Pin Repair - BS2 — Parallax Forums
gibbmangibbman Posts: 98
edited 2006-02-05 16:01 in Learn with BlocklyProp
Well, of course, eventually a student breaks a pin on their BS2. This one is P24, Vin. It partially seats in the socket, but really needs repair. Is there available a fix-it kit, or can someone point me to a source to find the necessary pin hardware to do the job? Since they are a little offset from the board pin, I can't really use a machine pin to replace it.
Jim
    edited 2006-02-03 21:09
    What I would do:
    1. Break off what remains of pin 24 on the BS2
    2. Get a 24-pin socket (machine pin type) and place a piece of straight wire in pin 24 socket and solder that into the socket and bend it over (not sharply)
    3. Seat the BS2 into the 24-pin socket
    4. Bend the wire soldered to the socket and solder it to the top of the BS2 board in the Pin 24 place
  • gibbmangibbman Posts: 98
    edited 2006-02-04 22:07
    PJ,
    Capital suggestion! Works fine, not hard to do. I'm thinking it might be a good idea to seat ALL the stamps in a quality socket, the machine pins of the socket make it much easier to in and out the things.
    Thanks again,
    Jim
    edited 2006-02-04 22:14
    Totally awesome, dude -- STAMP Onward!
    edited 2006-02-05 00:02
    gibbman,
    When I first started out I did what Pj Allen has described with other IC's I had.
    BTW) Wire wrap sockets work well for this kind of application. I guess you could call these "machine pin type"
    Beau Schwabe
    IC Layout Engineer
    edited 2006-02-05 14:35
    Thanks, Beau. I'll try that, also. Seems WW sockets have pretty long leads, would you clip these to avoid any
    "antenna" effect? Or not a problem at STAMP speeds...
    Jim
    · WW-terminals are not only long, but they're big, too.· I don't see anybody working/getting·one into an IC socket (the machine·pin sort --·no way; the side-wiper sort --·maybe once, with force.)· But, if you're of a mind to, you can probably make a lawn mower into a table lamp.
