SX-KeyRing now shipping for $9.95: build a 3.3V circuit with the SX
Hey SXers:
From your request in November, Parallax·introduced·the SX KeyRing again. You can use this tool with our SX-Key to run your system at 3.3V.
http://www.parallax.com/detail.asp?product_id=45211
These are only $9.95.
Sincerely,
Sincerely,
The original video module runs at 50MHz and uses about 80mA @ 5V = 400mWatts.
By tweaking the code I am able to run at 20MHz and use about 40mA @ 5V = 200mWatts.
Now to boldly go where no one has gone before... I see how low the voltage can go and still work properly....
Turns out to be about 2.4V and the current.... a mere 13mA = 31.2mWatts
So the original module uses 400mWatts and a low freq/low voltage module would use only 31.2mWatts! Less than 8% of the power required by the original.
Start looking for those low voltage parts boys...
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
It turns out that SX's can be lower power than PICs. Nice to see some confirmation of this. The last datasheet I looked at said 32MHz at 2.7 volts so your 20 at 2.5 is well within the spec.
If you just want low power, the TI MSP430 has just about everybody beat. That thing will run on static, I kid you not! Only a few MHz though.
The SX is still the best for speed AND low power at the same time.
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
I am using the Parallax 20MHz leaded resonator with OSCXT2 setting.
Below 2.4 it just stops altogether. I did notice that startup is somewhat iffy at 2.4 but seems fine at 2.5-2.6 volts.
Bean.
