Bluetooth
Hello,
Im thinking of making a wireless bluetooth network between my laptop and my robot. Can anyone sujest me a wireless USB cable that can go into my basic stamp and into my laptop? I saw a piece today in a store, you plug it into ure USB laptop and it can comunicate with anything that has USB. Im looking for somethink like that only it should comunicat with a second piece.
I dont know maybe somthing like this:
Boe-Bot(Basic Stamp)->USB
wireless
USB->Laptop
Is it possible?
Adrian
wireless
USB->Laptop
Is it possible?
Adrian
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (DarkSin) : 1/21/2006 12:03:11 AM GMT
P.S. And just to be sure, cause im kinda confused in this, will I still be able to receve data from my robot? like my purpose is making it travel arround the house transmitting tempreture and heat. I already have the sensor setup well. Will I be able to do that?
Post Edited (StarteR2) : 1/21/2006 4:32:35 PM GMT
·adapter for my laptop. To setup this thing how will i manage? can i use usb? help me pls with thisone
·Im asking this question vecause we need HyperTerminal for this usage. And in hyper terminal i Have 3 options to use the connect using thing
one is COM3 which aint serial,
Another TCP/IP Winstock
And some kind of HDAUDIO data fax modem.
THanks
p.s i couldnt buy a USB Board of education cause it was out of stock.
Post Edited (StarteR2) : 1/24/2006 1:46:21 AM GMT
http://www.parallax.com/detail.asp?product_id=800-00030
It's important that you load the VCP (virtual comm port) drivers before you use the device.· Once the driver is loaded, the adapter looks just like any other comm port to the software that wants to use it.· I use this device for programming SX chips and the BS1 (using the BS1 Serial Adapter) from my laptop USB port.
Jon Williams
a program? Like when i established secure conection between bluetooth(laptop) and eb500 it assigned port COM6 outgoing and COM7 incoming. I placed both in basic stamp and neither work. If its possible i want a method to be able to throw away the srial cable.
Adrian
