Error with SXSim — Parallax Forums
Error with SXSim
SamMishalSamMishal Posts: 468
edited 2006-01-13 03:21 in General Discussion
Mr Gunther,
I have found a problem in the SXSim programme
See the attached JPG also I am attaching the programme that caused it.
The two error·dialogues occured one after the other.
Also when I tried to use Explorer to get onto the forum
I got a message that there was not enough memory to tun
the programme. I had to reboot the computer.
I was "Running" the programme an using the I/O panel to view the
action.
All the programme does is reflect the input on RC onto RB.
I am just using this programme as a template file, that is why I have lots of other stuff.
The reason I am using an ISR to do the reflecting is just to test the ISR action
with the SXSim and the way the Template is done.
Regards
Samuel
Post Edited (SamMishal) : 1/11/2006 11:59:45 AM GMT
    edited 2006-01-11 22:49
    Samuel,
    thank you for reporting this problem. As far as I can remember, one or two users had similar problems with an older version of SXSim a while ago. Which version of SXSim and Windows are you using?
    I have tried your sample code here with the current version of SXSim running under WinXP and I could not reproduce this error. Nevertheless, your code, using the prescaler for the RTCC made me aware of a possible problem how SXSim handles it. I'll dig into it a bit deeper. In case, there is a bug, I'll have it fixed in the next release of SXSim.
    Greetings from Germany,
    G
  • SamMishalSamMishal Posts: 468
    edited 2006-01-12 00:00
    Mr. Gunther,
    I am using ver 2.08.03 under Window ME
    Samuel
    edited 2006-01-12 08:01
    Samuel,
    so you are using the latest version of SXSim. I have Win ME on une of my machines here. I'll try your sample code on this one, and will see what happens.
    G
    edited 2006-01-12 10:05
    Mr. Gunther,
    it does not happen straight away. Use run and then keep pressing a pin on the RC on the I/O panel.
    Press a button or different ones a few times. The message pops up randomly.
    regards
    Samuel
    edited 2006-01-12 13:23
    Hi Samuel,
    congratulations - you found a bug!
    In the meantime, I could reproduce (and fix) it. It actually had to do with the simulation of the RTCC prescaler - maybe, you are the first user who has ever activated the prescaler smile.gif . Sometimes, it could happen that the prescaler was not correctly reset causing that it cumulated values which made it overflow after a while.
    I'll post the new version 2.08.04 a bit later (see the first post in the "sticky" SXSim thread).
    G
    Mr Gunther,
    I am glad I can help in making this GREAT product aproach perfection.
    I REEEEEEEEALLY love your simulator. It is a great productivity tool. I can develop my program without even
    having the SX chip connected, which helps me when I am travelling and not in my office.
    I Love the SXSim.
    Thanks Mr. Gunther
    Samuel
