Problem conecting temperature sensor
I have a problem conecting the tempreture sensor. I dont really get it from the instructions since there is no step by step explanation. The diagram shows a sqaure with 8 pins. How do i place the sensor on the board and how do i make conections. Im very knew at this so please go easy on me [noparse]:)[/noparse] i found the resistors and all. Thanks alot.
Post Edited By Moderator (Chris Savage (Parallax)) : 1/6/2006 3:30:21 AM GMT
Without knowing what temperature sensor you are using (i.e. a part number) it's hard to determine what exactly it is that you may be having problems with.
Also, a more descriptive subject line might generate a better response.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/6/2006 5:00:36 AM GMT
·· It might also help to have a descriptive subject line explaining what your post is about.· I fixed this one for you.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Here are some of my unanswered questions.
Later i tried to do it on my own and here is what i got:
Square four went to a VSS
Square 3 went simply to pin 0 with resistor 4.7
Square one went to Pin 1
Square 8 went to Vdd
I used square cause i dont know how to call that
Post Edited (StarteR2) : 1/7/2006 2:53:11 AM GMT
Here are some applications notes for the SHTxx series of sensors, thanks to Dr. Tracy Allen: http://www.emesystems.com/OL2sht1x.htm
That should get you started.
Bruce Bates
