Problem conecting temperature sensor — Parallax Forums
StarteR2StarteR2 Posts: 27
edited 2006-01-07 08:59 in BASIC Stamp
I have a problem conecting the tempreture sensor. I dont really get it from the instructions since there is no step by step explanation. The diagram shows a sqaure with 8 pins. How do i place the sensor on the board and how do i make conections. Im very knew at this so please go easy on me [noparse]:)[/noparse] i found the resistors and all. Thanks alot.
Post Edited By Moderator (Chris Savage (Parallax)) : 1/6/2006 3:30:21 AM GMT
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2006-01-06 02:58
    StarteR2,
    Without knowing what temperature sensor you are using (i.e. a part number) it's hard to determine what exactly it is that you may be having problems with.
    Also, a more descriptive subject line might generate a better response.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 1/6/2006 5:00:36 AM GMT
    edited 2006-01-06 03:29
    Hello,
    ·· It might also help to have a descriptive subject line explaining what your post is about.· I fixed this one for you.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • StarteR2StarteR2 Posts: 27
    edited 2006-01-06 21:47
    SHT11 Sensor Module is the sensor, part number #28018.
    edited 2006-01-07 02:45
    Looking at the digram that came with the Sensor It says that it needs to be conected to Clock and at same time to Vss with 4.7 resistor? Where is the clock? why does it say Vss? What about Data? how do i connect to that? What about the Vdd on square #8, What aboutvthe resistors inside the sensor, do i have to plan them 2? What are these 8 squares? Hw do i insert the detector on the basic stamp pins?
    Here are some of my unanswered questions.
    Later i tried to do it on my own and here is what i got:
    Square four went to a VSS
    Square 3 went simply to pin 0 with resistor 4.7
    Square one went to Pin 1
    Square 8 went to Vdd
    I used square cause i dont know how to call that
    Post Edited (StarteR2) : 1/7/2006 2:53:11 AM GMT
    StartR2 -
    Here are some applications notes for the SHTxx series of sensors, thanks to Dr. Tracy Allen: http://www.emesystems.com/OL2sht1x.htm
    That should get you started.
    Bruce Bates
