Question about External Memory
I was wondering about interfacing a USB memory stick, you know, the ones on key chains and such, with the Javelin so it can store a large amount of data. Is this something that would do-able? I've looked for a USB interface chip, but all I can find, at least on parallax, is for USB to Serial. I'm still doing research, but I was wondering if anyone has had success with this. Eventually, I'd like to store pics taken by the CMUcam1 directly onto a removable USB memstick. Thanks for your time!
-Sean
-Sean
Here are some links, also this topic has been talked about quite a few times on the forum...
www.ghielectronics.com/ALFAT-SD.htm
www.ghielectronics.com/ALFAT%20DEV.htm
www.ghielectronics.com/USBwiz-OEM.htm
www.roguerobotics.com/products/electronics/ummc
There are others as well..
Bob N9LVU
