BOE-BOT with MAC troubleshooting
I have the USB version and am having difficulties connecting back to the MAC BS2 program. When I first open the application and download a program to the BOE-BOT, everything works fine. I disconnect the programming cable from the BOE-BOT because I'm running tests. However once I reconnect the programming cable to the BOE-BOT, the MAC BS2 doesnt connect. I'll switch USB ports and then it works, but then once i reconnect the programming cable it doesnt connect. Why is this? Anyone can help?
When i disconnect the programming cable from the BOE-BOT should I be turning power off? or can i just leave it to switch 1? Whats the proper procedure?
Jam
Jam
·· I have seen this on one customer's computer (Mac) before, but not supporting/using Macs, I did not know why it was happening.· I recall the same symptoms though.· It was a pain, but would work.· Typically USB is considered hot-pluggable/swappable and there is no need to shut either end down.· I doubt it would help anyway but maybe someone knows on the Mac why this is happening.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Chris Savage
www.muratnkonar.com/otherstuff/macbs2/faq.shtml
