THIN Q package?
Anyone ever used a "Thin Q" package?
I just ordered a few sample IC's from Maxim for something I want
to try and that's the only size they had available in their free samples.
MAX5481ETE & MAX5494ETE
I can't seem to get a decent package description other than it is
a 5mm square with 4-pins on a side for a total of 16 pins.
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
Had some time to kill at work and couldnt find anything clearer than this.
Both Package codes are on here its just figuring out everything. pdfserv.maxim-ic.com/package_dwgs/21-0136F.PDF
Paul
Post Edited (The-electronics-guy) : 12/23/2005 5:36:30 AM GMT
·1+1=10
I've done just that, after a fashion. I generally use a hot air gun (the soldering version of a hairdryer..Weller makes a great one) to preheat the board and the chip. For a Tripath board I did, I flowed about 3/4" of Kester 63/37 onto the heat slug on the board, and then placed the chip over it. With the heat gun on the bottom, occasionally alternating to the top, it took about 45 seconds to get the solder to reflow under the chip and sung it down nice and tight to the board. I liberally covered both the bottom of the package and the board slug with flux from a KEster flux pen before I started, and I think it helped a lot. I'd really prefer to do it in a batch oven, but I don't have one here at work any more, so I MacGuyver what I can.
It mostly works, but I never do it on one-of-a-kind things, because I have killed a few chips before. Not often, but once and a while.
-dave
This is not a sig. This is a duck. Quack.
Paul Baker,
Since this is a test circuit (wide range VCO application), and the IC's are
freebee’s, I was thinking about flipping the chip upside-down and connecting
it (bond wire fashion) to something more manageable like a DIP package for
testing purposes.
Beau Schwabe
IC Layout Engineer
······ Don't forget a penny for a heat sink!
(You might have to trim it down, but I promise not to call the T-men.)
John R.
8 + 8 = 10
The unfortunate thing is that most of the newer really nice SMT parts are only available in these leadless sizes and not the more useable SO-IC pkg but hey try to make a wireless ear mic in any older SO pkg and see how much the users ear droops. At least they aren't of the BGA style packages now these are impossible even with a solder plate.
Dedbugging the chip would work for prototyping, though you may have to account for lead inductance if the VCO frequency you are working with·is high enough.
·1+1=10
Post Edited (Paul Baker) : 12/23/2005 3:30:02 PM GMT
I understand what you are saying, but I don't think that the lead inductance will be so much as
a problem as parasitic resistance. The "digital pot" is NOT in the oscillator loop, and strictly
provides a voltage reference. By combining 3 "digital pots" with 10-Bit resolution in a particular
arrangement I can get a 20-Bit resolution output. Frequency "drift" from temperature is not too
much of a concern as long as the overall temperature is stable. The design will be able to
self-calibrate by reading back the actual frequency at specific known "digital pot" intervals.
Eventually I hope this project will move into the "Projects" folder, as I think it might be a valuable
testing tool for the hobbyist.
Beau Schwabe
IC Layout Engineer
