Two 9V Wall warts for 18V ???? — Parallax Forums
metron9metron9 Posts: 1,100
edited 2005-12-23 17:10 in General Discussion
I need 18V DC for a project of course RS had no 18V supplies, I was going to use a voltage regulator and a 36V (Only higher one they had) but decided 2 9V would do it
I thought it should work but it is not working.
WartAneg
WartApos-WartBneg
WartBpos
I only get 9V
Think outside the BOX!
  • SPENCESPENCE Posts: 204
    edited 2005-12-23 06:38
    Can't make it out from the pictures but you have to wire them in series..
    18vdc - or ground to neg side of number 1
    plus side of number 1 to minus(neg) side of number 2
    plus side of number 2 to 18vdc terminal.
    Should work ok......
    Check each one with a volt meter. Looks like you have it wired correctly.
    73
    spence
    k4kep
  • metron9metron9 Posts: 1,100
    edited 2005-12-23 07:05
    Yep it's wired correctly But I only get 9V on one supply connector and the rails are 9V but the other connector reads 0V. When I only plug in one supply and test the connector it works in each one.
    Perhaps because they are regulated supplys.
    Indeed, I happen to have another 9V 300ma supply that reads 15V (no load) I used that one with the regulated supply and around 25V (no load) so it must be because they are regulated supplys.
    So if I use an 800ma 9V and a 300ma in series I spose I should only expect the weakest link of 300ma to be my max draw?
    edited 2005-12-23 08:40
    God I can't believe I am so stupid
    After learning that there was indeed 390 mA flowing from the Positive of one wart to the negative of the other wart I said Hmmmm somthing is not right
    Of course it's not, both of the connectors are connected to an aluminum panel and thus are both connected to ground shorting out one of the warts
    Geeeesssssssssss
    Now thats better and with indicator lights as well, who could ask for anything more?
    640 x 480 - 61K
