Two 9V Wall warts for 18V ????
I need 18V DC for a project of course RS had no 18V supplies, I was going to use a voltage regulator and a 36V (Only higher one they had) but decided 2 9V would do it
I thought it should work but it is not working.
WartAneg
WartApos-WartBneg
WartBpos
I only get 9V
Think outside the BOX!
WartAneg
WartApos-WartBneg
WartBpos
I only get 9V
18vdc - or ground to neg side of number 1
plus side of number 1 to minus(neg) side of number 2
plus side of number 2 to 18vdc terminal.
Should work ok......
Check each one with a volt meter. Looks like you have it wired correctly.
73
spence
k4kep
Perhaps because they are regulated supplys.
Indeed, I happen to have another 9V 300ma supply that reads 15V (no load) I used that one with the regulated supply and around 25V (no load) so it must be because they are regulated supplys.
So if I use an 800ma 9V and a 300ma in series I spose I should only expect the weakest link of 300ma to be my max draw?
After learning that there was indeed 390 mA flowing from the Positive of one wart to the negative of the other wart I said Hmmmm somthing is not right
Of course it's not, both of the connectors are connected to an aluminum panel and thus are both connected to ground shorting out one of the warts
Geeeesssssssssss
