power supply by small Solar Panel
Hello everyone,
I’m working in an electronics art project and I need a little help:
I’m working in a circuit with a BS connected to a LCD, and I need to use only solar light as power supply.
Who can I give enough power with a small solar panel for this circuit?. Who can I connect capacitors to make it work?, which size should they bee?
The solar panels and the LCD must bee as small as possible.
What BS model should I use?
Any ideas for the solar panel?. (http://www.powerfilmsolar.com/products/oem_components/index.htm)
Any ideas for the LCD? …
Thank you,
Felix.
www.othersounds.net
Thank you,
Felix.
www.othersounds.net
·· The LCD question has already been addressed in your other thread.
Chris Savage
Parallax Tech Support
csavage@parallax.com
It is possible to run LCD displays at very low current, but those seem to be mostly custom jobs. What information do you need to display? If it could be a simple 4 digit numeric display you would have more options than if you need a full multiline or graphics display.
Tracy Allen
www.emesystems.com
Thank you for your help!.
I need the LCD to be on "as much as possible", so that the public can read the information from time to time. But it can go on-off with a certain frequency, it is not a problem. The light exposure isn’t ambient light: It’s a room in an art museum, but I can put a lamp facing the solar panel at approximately ½ meters.
I need to display text information, a few phrases…
I hope it clarifies a little bit my request. If you need any more info, please ask
Thanks again!
Felix
www.othersounds.net
Truly Understand the Fundamentals and the Path will be so much easier...
Tom Walker is right:
"Using a lamp over a solar panel is a terribly inefficient way to get power"
But art is often an inefficient science!.
This is a conceptual project, we are not dealing with "real situations" and there aren’t any educational purposes.
The circuits will bee integrated in a sculpture, which must bee illuminated.
Thanks for the help,
Felix
www.othersounds.net
