Question concerning FPU-co
I was just reading over some of the documentation on the FPU math co-proc and I was wondering, when used with a Javelin, do I need to construct some UART objects to handle the data or is it taken care of by com.micromegacorp.math.v2_spi.*? Just trying to puzzle out why I can't get it (FPU) to recieve a reset command. Thanks!
http://www.micromegacorp.com/javelin.html
version 1.1 Fpu shows:
* V1.1 - September 21, 2005
* - corrected bus assignment in reset method
regards peter
Post Edited (Peter Verkaik) : 12/21/2005 12:12:32 AM GMT
Graph
uM-FPU not responding.
I'm fairly certain I have it hooked up properly though (though I do not have a DS1620 thermometer, it should still be able to reset the FPU).
Using the SPI hookup, I have FPU.pin1(CS) wired to pin4 (VSS) and then to ground (Vss). Pin2 has a 1k resistor to pin5 with a wire between them(pin 5 and the 1k resistor that is) going to P14(Javelin). Pin3 goes straight to P15 (Javelin). Pin6 leads no where. Pin7 grounds (Vss) and Pin8 has 5v @ Vdd.
The only other thing hooked up to the BoE are two servos, which I don't even enable while trying to run Graph.java.
Any ideas would be really appreciated. Thanks!!
-Sean
Please post your code.
regards peter
Have you checked if both these pins actually become low outputs?
Try·this:
static void main() {
· CPU.writePin(CPU.pin14,false);
· CPU.writePin(CPU.pin15,false);
· while (true) ;
If you run this test program you·can check the pin voltages.
Between each pin and +5V·you must measure 5V. These pins also
must be able to light a LED via 1k resistor to 5V.
If either pin is not low, then you must use other pins for Fpu.
regards peter
I didn't actually get your code to compile, it said Syntax: Unexpected input discarded, however, I went ahead and changed the pins in FPU.java in the v2_SPI folder and physically changed it as well and poof! It works! Thank you!!! Now I can finally do sigmoid functions that my neural net will need (as soon as I puzzle that out! heh). Thank you!!
-Sean
You should find out at some time if your javelin pins 14 and/or 15 are damaged.
Because you changed pins and did not check 14 and 15 (did you?) it could
also have been·a faulty wire connection.
regards peter
