Question concerning FPU-co — Parallax Forums
YojimboYojimbo Posts: 40
edited 2005-12-21 02:54 in General Discussion
I was just reading over some of the documentation on the FPU math co-proc and I was wondering, when used with a Javelin, do I need to construct some UART objects to handle the data or is it taken care of by com.micromegacorp.math.v2_spi.*? Just trying to puzzle out why I can't get it (FPU) to recieve a reset command. Thanks!
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2005-12-21 00:08
    Have you checked the uM-Fpu javelin support here:
    http://www.micromegacorp.com/javelin.html
    version 1.1 Fpu shows:
    * V1.1 - September 21, 2005
    * - corrected bus assignment in reset method
    regards peter
    Post Edited (Peter Verkaik) : 12/21/2005 12:12:32 AM GMT
  • YojimboYojimbo Posts: 40
    edited 2005-12-21 00:39
    Well, I updated, but it seemed to have no effect. I uploaded the Graph.java program to the Javelin but all I get is:
    Graph
    uM-FPU not responding.
    I'm fairly certain I have it hooked up properly though (though I do not have a DS1620 thermometer, it should still be able to reset the FPU).
    Using the SPI hookup, I have FPU.pin1(CS) wired to pin4 (VSS) and then to ground (Vss). Pin2 has a 1k resistor to pin5 with a wire between them(pin 5 and the 1k resistor that is) going to P14(Javelin). Pin3 goes straight to P15 (Javelin). Pin6 leads no where. Pin7 grounds (Vss) and Pin8 has 5v @ Vdd.
    The only other thing hooked up to the BoE are two servos, which I don't even enable while trying to run Graph.java.
    Any ideas would be really appreciated. Thanks!!
    -Sean
    edited 2005-12-21 00:58
    You have the javelin GND and Fpu GND connected, as they must?
    Please post your code.
    regards peter
    edited 2005-12-21 01:03
    I think it's grounded properly, I have it wired just as the diagram describes for SPI in the javelin FPU-co PDF linked here (page 2). The code I am using is stock, and attached. Though I am not what you meanwhen you refer to the Javelin being grounded, it is resting in it's socket.
    edited 2005-12-21 01:16
    Ok, the Fpu reset starts with toggling javelin pins 14 and 15.
    Have you checked if both these pins actually become low outputs?
    Try·this:
    static void main() {
    · CPU.writePin(CPU.pin14,false);
    · CPU.writePin(CPU.pin15,false);
    · while (true) ;
    If you run this test program you·can check the pin voltages.
    Between each pin and +5V·you must measure 5V. These pins also
    must be able to light a LED via 1k resistor to 5V.
    If either pin is not low, then you must use other pins for Fpu.
    regards peter
    edited 2005-12-21 02:01
    Thank you thank you thank you thank you thank you!!!
    I didn't actually get your code to compile, it said Syntax: Unexpected input discarded, however, I went ahead and changed the pins in FPU.java in the v2_SPI folder and physically changed it as well and poof! It works! Thank you!!! Now I can finally do sigmoid functions that my neural net will need (as soon as I puzzle that out! heh). Thank you!!
    -Sean
    Great that it works.
    You should find out at some time if your javelin pins 14 and/or 15 are damaged.
    Because you changed pins and did not check 14 and 15 (did you?) it could
    also have been·a faulty wire connection.
    regards peter
