Qbasic <=> Stamp2 communication ? (Qbasic primarily)
Does anyone know how to get bidirectional communication between a BS2 programming port and Qbasic working?
I have been able to get the stamp to send data to the PC, want to be able to control the flow so that data is not lost
basically like this
PC sends the read command "00"
stamp replies with data
just that I have been unable to change direction without resetting the stamp via DTR (don't want to hack a cable)
1. what method of opening the port is suitable for this?
2. what commands are used to read from / write to the port?
I tried opening the port in random access mode, opens ok but get a device timeout on the "print #" line (the method I found
online to talk to a modem)
thanks in advance
edit: been using the standard debug settings for the port 9600 8N1
Post Edited (CJ) : 12/17/2005 4:36:39 AM GMT
basically like this
thanks in advance
It's been a long time since I used Qbasic to communicate with a Stamp, but I will take you back a few years
when I was writing Qbasic to Stamp code left and right.
As far as the DTR line, there is a software solution (provided in link below) as well as a hardware solution. The
hardware solution uses two caps in a specific configuration. ( ASCII below )
.1uF ATN >--o--||----< DTR ( DB9 Pin 4 ) | o--||----< VSS ( DB9 Pin 5 ) .1uFwebpages.charter.net/schwabelove/BasicStamp/Communication/Index.html
Beau Schwabe
IC Layout Engineer
